Write Up: Replace the Turn Signal Switch on 97+ XJ - Page 4 - JeepForum.com
post #46 of 74 Old 08-10-2012, 10:37 PM
sbxj
sbxj's Avatar
different setup entirely up to '96
'01 XJ 2DR Sport
'99 WJ Laredo, 4.0L with HID Retrofit
sbxj is offline
post #47 of 74 Old 09-02-2012, 11:00 AM
berger150
Before you do anything be sure to check each bulb & the connection.
I nearly replaced my turn signal switch. But luckily my left front parking light went out. I went to replace it & found it wasn't put in correctly by the previous owner & once I replaced the bulb & put it in correctly. The alarm & signal staying on ..stopped. Have not had a problem since & that was over a year ago.
2006 Wrangler 65th Anniversary Edition
berger150 is offline
post #48 of 74 Old 11-29-2012, 09:29 PM
OnTheFence
Last 3 photos totally lost me.
I had no idea what he was even talking about.
No clue what I am even looking at.
Well, at least I know how to remove the cover. Ha
OnTheFence is offline
post #49 of 74 Old 12-23-2012, 07:29 PM
OnTheFence
Why do other threads say you need to pull the steering wheel?
http://www.cherokeeforum.com/f2/turn...removal-94548/
post #50 of 74 Old 12-23-2012, 08:53 PM
stretch2187
Looks like they're talking about pre-1996 models. I changed the turn signal switch on my 1999 XJ in 15 minutes following the instructions on this thread. (No pulling the steering wheel was required.)
stretch2187 is offline
post #51 of 74 Old 04-22-2013, 02:45 PM
SKINUM
Easy swap on my 05LJ. The only part that confused me for a second was that I needed to remove my wiper switch & place it in the new unit. I assumed both the signal & wiper switch would come in one unit.
I guess it would've helped if I had noticed there was only one lever on the unit when it was delivered. :>)
SKINUM is offline
post #52 of 74 Old 04-22-2013, 07:49 PM
DrewzillaXJ
1997 XJ Cherokee
I just did this. Excellent write-up!
DrewzillaXJ is offline
post #53 of 74 Old 05-15-2013, 08:27 AM
blablathingy
This is awesome!
Thank you for this - it's exactly what I need to do on my jeep. Will be my first car repair ever. But your tutorial looks great - think I can do it.
blablathingy is offline
post #54 of 74 Old 05-16-2013, 03:52 PM
OnTheFence
I just ordered one for $30 off Ebay.
post #55 of 74 Old 05-17-2013, 08:19 AM
Gelertazreal
My stalk broke of yesterday..half way home...so right now no turning lights or wipers.
Would this be tge same kind of deal with the 91XJ ?
Gelertazreal is offline
post #56 of 74 Old 05-17-2013, 09:32 AM
bobbo_xj
There are definately subpar multifunction switches out there. I replaced ones from an 01 xj and a chysler T&C within 18 months. Found luck buying from NAPA. I believe they still sell a good one under the echlin name.
2001 XJ Sport, 176k mi.
bobbo_xj is offline
post #57 of 74 Old 06-16-2013, 08:55 PM
MDchanic
Originally Posted by hdsport View Post
I am a "take apart" person and have developed a method to completely disassemble these switches and recondition them. I love to do detailede work and these were a challenge to me a couple of years ago. There are a lot of internal parts and the reassembly is a little tricky, but if you are careful, it can be done.
My time is abour 1 1/2 hours to do one of these.
I am currently doing this for a local shop with 100% success.
If anyone would like a rebuild, please let me know.
Also, I would consider buying your old one to keep in stock.
Instead of throwing your old one away, I could get you $10 plus shipping for your old one....help defray the cost of a new one.
These will easily fit into a USPS Priority Mail soft envelope...$4.95 anywhere.
Email me at: pjb7@live.com for info.
Thanks,
Paul
Thank you, Paul, for letting me know that it is possible to "rebuild" (actually just clean up) these switches. If I hadn't known that "someone" had gotten one back together, just one time, I would have given up and bought a new one.
In my case, my "new" 2000 Cherokee showed three symptoms:
  • Right turn signal was sluggish - would "fast flash" a few times before settling in to a normal flash rate,
  • 4-Way flashers would flash only the Left signal indicator (turning the directional switch to signal right would make both flash), and
  • 4-Way flashers would only flash the Left outside signals (turning the directional switch to signal right would add the Right Rear to the Left signals, but the Right Front would never come on).
I removed the old switch (quite easy, really, but, oh boy, all the dirt and dog hair that were jammed into that rubber gaiter...), took it inside, and took it apart.
Like everything, taking it apart was very easy. It would be a bit harder to figure out where all those little parts that flew out were supposed to go.
Inside, the majority of the contacts were green with corrosion.
I cleaned all the old (and green) grease off of them with some lacquer thinner, then gave them a good scrub with a Dremel with a tiny wire brush attachment 'till they shined, then cleaned the grease I'd dredged up off of them again with more lacquer thinner. When I was done, all was shiny.
I coated it with a nice, slippery grease (I like heavy-duty clear red grease-gun grease because a thin film is very slippery, and I avoid dielectric grease because it insulates, and I'd rather not introduce an additional potential bit of resistance to the circuit).
Now began the conundrum of how to reassemble.
It seemed obvious at first (doesn't it always?), but the first three times I put it together, I got it wrong.
I finally figured out the trick, and got it on time #5.
I did not take pictures, but the trick is to assemble everything into the black half (the half with the plug receptacle - the side that faces toward the front of the car), except for the signal lever. This includes
  • the 4-way slider (which has the 4-way tab on top),
  • the directional signal slider (which interlocks with it, just below it), and
  • the little contact slider for the high beams, which would seem to need to hang on the end of the signal lever, but does not.
The little high beam slider should be set as high in its groove as it can be, so you can grab it with the end of the signal light lever when you mate the two switch halves.
The directional and 4-way sliders should be set toward the right of their travel.
Assemble the signal lever to the white side:
  • The large, heavy spring fits into the curved groove in the surface of the lever base that faces the white plastic case half (faces the driver when seated in the car) and acts to return the signal light lever to center after you signal right or left.
  • The long, thin spring goes on the two posts with tabs on their tops (which hold the spring in place), and goes through the space in the signal lever base that lies between the two posts.
Get the lever assembled to the white half and the other parts assembled to the black half, then slowly introduce the two halves.
The offset pin on the lever has to go into the groove in the signal light slider (which was white on my switch), then you have to come in a bit sideways to grab the slot of the highbeam slider with the tab at the end of the signal light lever. Once you grab it, you can press the switch halves straight together, giving the signal light detent finger a bit of a nudge with the end of a screwdriver, to get it to snap into its spot, and then install the four screws.
Getting this switch together is about as complicated as it sounds, though doing it wrong four times in a row can really help you to get it right.
I figure if you read this first, you may get it on the second or third try .
Good luck, and thanks for this thread - it was very helpful to me, and I hope that this post gives back just a little bit.
- Eric
MDchanic is offline
post #58 of 74 Old 06-17-2013, 03:56 AM
hdsport
2008 WK
GREAT.
Can't beat fixing something yourself and get the satisfaction of doing it.
Thanks for sharing this with us.
Paul
2001 Winnebago Adventurer 32v Motor Home
2008 Jeep GC Limited Toad, 4.7 L V-8, QTII
US Army Vet, 8th Army, 11th Evac SMBL Hospital, Pusan, South Korea
In God We Trust
hdsport is offline
post #59 of 74 Old 07-27-2013, 07:32 PM
ChasUGC
Thank you very much for this FIY information. The turn signal on my '97 Wrangler Sport was constantly sticking. The switch just wouldn't disconnect after a turn most of the time.
It was very irritating, especially while trying to listen to music. I just replaced it with the help of this article, in less than an hour. I also painted the shroud covering it. And, I used a little clear coat over the labels so they wouldn't rub off. Now, it looks great and functions perfectly.
Thank you for this article.
Fondest Jeep Memory: I was on the 710 freeway during a flood. Cars and Trucks were stuck in a flooded under pass. The water was at least three feet high. People were standing outside of their cars waving me off, saying that I would get stuck. I just smiled, put my Jeep into 4-wheel drive, and drove right through it
without a hitch. I was so proud of my Jeep that day.
ChasUGC is offline
post #60 of 74 Old 08-03-2013, 07:04 PM
bingles
Great write up. Replaced this switch in my 2000 today and works like a charm. Thanks!
bingles is offline
Turn signal switch/multi-function switch same thing? Strokin87 XJ Cherokee Technical Forum 15 12-15-2012 03:44 PM
Left turn signal blinking really fast after trying to replace Mikej1224 XJ Cherokee Technical Forum 7 12-30-2009 03:13 PM
I NEED HELP!!! Turn signal switch/stalk orangepower1987 XJ Cherokee Technical Forum 11 09-17-2009 01:28 PM
how to replace turn signal lever jeeptorino68 XJ Cherokee Technical Forum 10 08-01-2008 11:04 PM
turn signal switch boise49ers XJ Cherokee Technical Forum 3 05-31-2004 10:37 PM
