wont start still!!! - JeepForum.com
post #1 of 17 Old 06-29-2013, 07:05 PM Thread Starter
lance89xj
1989 XJ Cherokee
wont start still!!!
I have an 89 Cherokee 4.0l. one day it was running just fine the next it just cranks but wont fire up. I have replaced fuel pump and filter, dizzy and roter and cap, plugs and wires, ICM and coil and the CPS. oh and the timing chain and gears. still nothing. I did a compression test and it was all outta wack so I pulled the head off and had it shaved and one valve seal fixed. put it all back together and its still doing the same thing it was before I started replacing stuff. please help im at wits end with this.
lance89xj is offline
post #2 of 17 Old 06-29-2013, 08:03 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
You need to do some basic troubleshooting to see what you are missing. Fuel, spark and compression.
1. Do you have a strong, BLUE, snapping spark?
2. Do you have approximately 31 psi of fuel pressure at the fuel rail measured with a fuel pressure gauge?
3. What do you mean by the compression was out of whack? What were the "before" and "after" compression readings. The spec for the 4.0 is 120-150 psi, with no more than a 30 psi variation between cylinders.
Gotta start with the above three things.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is online now
post #3 of 17 Old 06-29-2013, 11:25 PM Thread Starter
lance89xj
1989 XJ Cherokee
okay so I just cheaked the spark and its bright blue. and the compression is #1,80 #2,80 #3,75 #4,90 #5,95 #6,95. now im gonna run to the parts store to get a fuel presior tester.
post #4 of 17 Old 06-30-2013, 12:28 AM
Hudson
Fuel is not your problem.
I mean it could be, but something is seriously wrong internally with that engine. None of those cylinders are within spec.
Did you do a wet compression test or dry? (Wet compression test is when you add oil to the cylinder to see if the rings(?) are sealing.)
Live To Die. You're Not Going To Get Out Of This One Alive.
Build Thread - http://www.ausjeepoffroad.com/forum/showthread.php?t=121903
Hudson is offline
post #5 of 17 Old 06-30-2013, 01:46 AM Thread Starter
lance89xj
1989 XJ Cherokee
I did a dry test. and ill do the wet test tomorrow along with a fuel pressure test. It sounds like its super close to starting when I add fuel in the T.B. witch leads me to belive its a fuel problem.
post #6 of 17 Old 06-30-2013, 01:51 AM
xrunndonex
1994 ZJ
hook up jumper cables and crank away don't crank to long and give it like minute breaks to recharge mine did that once turns out I got a battery with hardly a charge on it
xrunndonex is offline
post #7 of 17 Old 06-30-2013, 02:18 AM Thread Starter
lance89xj
1989 XJ Cherokee
nope its not the battery.
post #8 of 17 Old 06-30-2013, 02:19 PM
Kalali
What's the point in trying to start an engine with that much compression? You'll soon need to add a starter and battery to the list of parts that you'll be replacing. Isolate the cause of low compression between the valves and the rings and fix the root cause. How many miles on the rig?
Kalali is offline
post #9 of 17 Old 06-30-2013, 02:50 PM
MarkwithaK
My '98 did this when I first bought it. Ended up being the ignition coil.
MarkwithaK is offline
post #10 of 17 Old 06-30-2013, 05:01 PM Thread Starter
lance89xj
1989 XJ Cherokee
there is 207XXX miles. its got a new battery when I bought it. and its got a new coil too. I guess I need to do a wet test and see if the rings are sealing or not
post #11 of 17 Old 06-30-2013, 05:26 PM
xrunndonex
1994 ZJ
How many times have you tried to start it?
post #12 of 17 Old 06-30-2013, 06:03 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Sure seems as if some thorough diagnostics in the beginning woulda been good instead of shotgunning parts and stuff. Just sayin. I'm wondering if the cam is timed correctly.
This is a good lesson for others.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #13 of 17 Old 07-01-2013, 05:49 AM Thread Starter
lance89xj
1989 XJ Cherokee
probly 20 times or more.
post #14 of 17 Old 07-01-2013, 05:51 AM Thread Starter
lance89xj
1989 XJ Cherokee
207700 miles on her
post #15 of 17 Old 07-03-2013, 05:13 PM Thread Starter
lance89xj
1989 XJ Cherokee
Okay so due to everything being good except for the compression im going to replace the piston rings and inspect the lifters and camshaft now. keep yall updated
