Won't Start-- Not Battery - JeepForum.com
post #1 of 6 Old 08-17-2005, 04:11 PM Thread Starter
Goober_Rocks
Unhappy Won't Start-- Not Battery
So my Jeep isn't starting at all right now. If I have a friend jump it, it starts and runs just fine. I've checked the battery and the cables with a voltmeter, and they are all fine. I assume the alternator is fine as the battery has a normal charge. Other ideas?
'89 Cherokee 4.0 L
4WD - - Stock
240,000 miles
'03 Grand Cherokee
70,000 miles
Goober_Rocks is offline
post #2 of 6 Old 08-17-2005, 04:14 PM
kg6mti
1987 YJ Wrangler
It could still be your battery. If your battery isn't putting out enough amperage then it won't be able to start your engine. It is possible for the battery to display full or near full voltage but low amperage. I would recommend getting the battery tested. But your problem could also be your starter or the solenoid. Any good auto parts store should be able to test all these parts for you but you will have to remove them.
Good Luck!
Experience is what you get when you get what you didnít want.
kg6mti is offline
post #3 of 6 Old 08-17-2005, 04:16 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
If it needs to be jumped to start it, that would point towards a bad battery. Sometimes, individual cells in the battery can go bad. The battery will still read 12v, but it won't put out the amperage to crank the engine.
Looks like someone beat me to it...
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #4 of 6 Old 08-17-2005, 04:22 PM
Boomhauer
Mine had the same prob as yours. jump it and was good, but it would only hold a charge for about 6-8 hours. It was the battery. Hope this helps.
Boomhauer is offline
post #5 of 6 Old 08-17-2005, 04:25 PM
anony91xj
Good Luck!
What he said. A voltmeter is effectively useless at testing batteries (automotive or otherwise) unless it can put a load on it.
Most national chain auto parts stores (AutoZone, Advance Auto Parts, Pep Boys, etc) will test your battery, starter, and alternator for free. Go to one of those places and see what comes up, I bet it's a bad battery.
Not for nothing, but the terminal connectors are tight on the battery, right?
1998 VW GTI 2.0
anony91xj is offline
post #6 of 6 Old 08-17-2005, 05:25 PM Thread Starter
Goober_Rocks
Thanks everyone, just took a new battery. It started up just fine after that. I like the simple fixes.
4.0 battery on, starter replaced no start orangekid XJ Cherokee Technical Forum 15 12-22-2009 06:05 PM
I put the battery in backwards and now it won't start. socalbro84 XJ Cherokee Technical Forum 8 11-24-2009 10:40 AM
Battery, Bought a new one, now won't start Weston3220 XJ Cherokee Technical Forum 7 08-28-2009 12:48 PM
interesting hard start/no start/dead battery problem TXjeep97 XJ Cherokee Technical Forum 4 02-18-2008 08:18 PM
Battery Power But No Start...Help!!! JSPRE XJ Cherokee Technical Forum 2 08-18-2007 04:03 PM
