WON'T START! Fried battery? Big 'ol short? - JeepForum.com
post #1 of 8 Old 11-03-2004, 10:10 AM Thread Starter
mchlwise
Exclamation WON'T START! Fried battery? Big 'ol short?
I went to start my 1990 XJ Limited this morning, and nothing. I mean absolutely nothing. No lights, no horn, nothin. It's dead. No juice at all from the battery, an dit was just driven last night with no problems.
So I get out my battery charger and hook it up. Lots of pretty sparks, and the amp meter on the charger SPIKES stays there for a couple seconds, and then the built-in safety in the charger cuts it off.
First thought is it looks like there's a SERIOUS short somewhere that drained the battery and is still shorting out, causing the huge draw when I hook up the charger.
So I disconnected the negative (ground) cable from the battery. I hooked the charger back up to the battery, negative to the negative post and positive to the positive cable (which was still hooked up). Exactly the same thing happened. Pretty sparks, spikes amp meter for a couple seconds, then automatic cut-off.
I was already late for work so I couldn't mess with it any more, but as I'm thinking about it, it doesn't make sense. If it's a short, with my ground cable disconnected from the battery and not touching anything, how is it completing the circuit from the positive charger cable to the negative battery post without the ground cable? It is the battery itself that's fried?
Any suggestions would be appreciated.
mchlwise is offline
post #2 of 8 Old 11-03-2004, 10:46 AM
ctavel
ctavel's Avatar
Yeah I would trace all grounds and make sure they are wired where they are supposed to be. I would also go ahead and replace the terminals, and the cables attatched to the terminals. I was having power issues a while back and they were due to a bad ground at the battery, so that may be your problem
ctavel is offline
post #3 of 8 Old 11-03-2004, 02:06 PM Thread Starter
mchlwise
Arrow Update
The battery's fried.
I went home at lunch and disconnected the positive cable, removed the battery from the Jeep, and hooked up the charger to the battery. It acted the same way, amp meter pegged off the dial. I pulled a battery off another car, hooked it up, and the Jeep started right up and did everything else it was doing before (There's still stuff not working, but that's another post)
Has anybody heard of a battery doing this before? I've seen batteries "go bad" and not hold a charge, but I've never seen one short itself out like that before.
I'm thinking a new battery after work and it should be just fine.
mchlwise is offline
post #4 of 8 Old 11-03-2004, 02:37 PM
ctavel
ctavel's Avatar
Thats crazy, what kind was it? You could try changing the termanials themselves, its easy and if it doesn't fix anything then your only out like 10 bucks.
ctavel is offline
post #5 of 8 Old 11-03-2004, 02:39 PM
xj4play
xj4play's Avatar
2004 KJ Liberty
Yup, it's fried alright. The plates inside the battery become corroded, deteriorate and pieces fall across the others and short the battery out bigtime.
While you have the battery out, do yourself a favor and check out the battery cables - replace them if they look like they need it.
Leave no bolt unturned...
1998 ZJ Laredo
4.0 IL6, 42RE Tranny, 242 TC, 2" lift, Cragar Soft 8's, 30" BFG All Terrains
xj4play is offline
post #6 of 8 Old 11-03-2004, 02:42 PM
CODE
The battery can have an Internal Short, it happens from time to time. So when you put the charger on it you will pull rediculous power from the charger (equivelant to shorting).
It is not an overly special situation. Although it usually doesn't go to that extream in my experience.
I hope the new battery serves you well!
DaveH.
CODE is offline
post #7 of 8 Old 11-03-2004, 03:18 PM Thread Starter
mchlwise
Thumbs up
Thanks for the replies
I've never seen a battery do that before, but there's a first time for everything. It was a Diehard, and since I've only had the Jeep a few weeks, I have no idea how old it is.
When I pulled the battery, I noticed that whatever was supposed to be securing it was missing, so it was just sitting there loose, free to bump around. I'm betting that's what happened - it took a hard jolt, a plate came loose inside and is shorting everything out.
I'm glad it was just a battery - replacing it is a lot easier than chasing down and replacing half my wiring. I will be taking a look at things, though, and make sure there aren't any other problems.
Jeep on!
mchlwise is offline
post #8 of 8 Old 11-04-2004, 09:02 AM Thread Starter
mchlwise
Thumbs up
Just to close out the post:
A new battery and a home-brewed battery restraint (since the stock one was missing) to keep it from bouncing around, and it's better than ever!
mchlwise is offline
96 Cherokee 4.0, Can short starter, but can't key start Urbanmedic XJ Cherokee Technical Forum 4 11-25-2009 10:53 PM
Short SOMEWHERE is Killing My Battery... xjarchaeologist XJ Cherokee Technical Forum 5 09-07-2009 09:56 PM
short rough idle after start up Muddeprived XJ Cherokee Technical Forum 13 08-12-2009 04:42 PM
interesting hard start/no start/dead battery problem TXjeep97 XJ Cherokee Technical Forum 4 02-18-2008 08:18 PM
Jeep won't start after short drive in the cold smuth XJ Cherokee Technical Forum 5 01-08-2008 05:25 PM
