Won't crank won't start - JeepForum.com
post #1 of 21 Old 07-06-2017, 07:17 PM Thread Starter
austin6137
1990 XJ Cherokee
I haven't been on here as much as I once was but I have a problem and need advice. My jeep doesn't see much use but today I went to start it and well I got nothing. I know what your thinking battery is dead, well it's not I unhook it when I know it's gonna sit and I hooked it back up when I go to use it. Battery is good that's not the issue, when I go to turn the key it won't crank won't do anything, radio, hvac, anything that's ran off the ignition doesn't work, but the interior lights, headlights and tail lights all work. Could it be the ignition switch I've never had a problem with it before?
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
post #2 of 21 Old 07-06-2017, 11:15 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
A no-crank scenario often ties to a dirty or failing Neutral Safety Switch, particularly after extended non-use.
Try moving the shifter front to rear several times and starting in neutral.
***Chris***
chris87xj is online now
post #3 of 21 Old 07-07-2017, 07:55 AM Thread Starter
austin6137
1990 XJ Cherokee
My jeeps 5 speed
post #4 of 21 Old 07-07-2017, 09:04 AM
cruiser54
1990 MJ Comanche
Something ain't getting from the battery to the ignition switch........
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #5 of 21 Old 07-07-2017, 05:58 PM Thread Starter
austin6137
1990 XJ Cherokee
What feeds the ignition, I'm pretty sure all the fuses are good
post #6 of 21 Old 07-10-2017, 11:46 AM Thread Starter
austin6137
1990 XJ Cherokee
Bump
post #7 of 21 Old 07-10-2017, 06:10 PM
cruiser54
1990 MJ Comanche
This:
Starter relay connections.jpg   starter relay diagram-001.jpg   renix relay center.jpg
post #8 of 21 Old 08-15-2017, 06:43 PM Thread Starter
austin6137
1990 XJ Cherokee
Changed that still nothing
post #9 of 21 Old 08-15-2017, 06:48 PM
deadcode
Check the fuel pressure on the rail? If there's no fuel, it won't even crank.
"The distance between insanity and genius is measured only by success."
- Bruce Feirstein
deadcode is offline
post #10 of 21 Old 08-15-2017, 07:38 PM Thread Starter
austin6137
1990 XJ Cherokee
It's not fuel related
post #11 of 21 Old 08-15-2017, 10:09 PM
Nick05
1994 XJ Cherokee
How's your clock spring? My 95 had a wire not making good contact in the clock spring and it would die and not do anything. I had headlights but no vents, radio or crank.
Nick05 is offline
post #12 of 21 Old 08-16-2017, 05:00 AM Thread Starter
austin6137
1990 XJ Cherokee
Don't have one
post #13 of 21 Old 08-16-2017, 09:17 AM
Nick05
1994 XJ Cherokee
Don't have one
You should. It is in the steering wheel
Nick05 is offline
post #14 of 21 Old 08-16-2017, 06:02 PM Thread Starter
austin6137
1990 XJ Cherokee
I know what a clockspring is, I have renix era Cherokee
post #15 of 21 Old 08-16-2017, 06:44 PM
Nick05
1994 XJ Cherokee
Didn't know they didn't have one. I will have to remember that when i finally mess with my mj again.
Nick05 is offline
