wobbling/shimmy - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > wobbling/shimmy
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 06-27-2009, 11:33 PM   #1
jjg214
wobbling/shimmy
hey, iv read a bit on the infamous "death wobble" but im looking for some more advice specific to my symptoms.
i have OME HD packs in the back and 2 inch coil spacers up front. the jeep has been riding this suspension for a few months without any problems. I took it on a 250 mile trip upstate and notice that at 50 mph when braking there is was a slight shake in the steering wheel. Now, the next day, im still upstate and it has progressed from a shaking in the wheel to the entire jeep shaking very violently.
It doesnt happen at any other RPM or MPH except when slowing from 50 to 45 while on the brake, if you coast through it nothing happens. so i suspect some problem with the brakes and would like to get ti resolved before i leave on monday. thanks for any help
jjg214 is offline   Reply With Quote
Unread 06-27-2009, 11:35 PM   #2
DC4W-93XJ
1990 XJ Cherokee
sounds like tire balance is outa whack to me... only other thing it could be is your tow isn't set right...
THIS AIN'T YOUR MAMA'S STATION WAGON!!
Built Jeep Tough With Chevy Stuff
"Tater 2" '91 2 door XJ chopped and bobbed, 4.0, AW4, dana 300, GM 60/70HD, 40" IROKs on H1s
SEE THE BUILD HERE
DC4W-93XJ is offline   Reply With Quote
Unread 06-28-2009, 12:05 AM   #3
MJR
Sounds like two issues. One being brake rotor warpage (have them machined or replaced) and what is called Death Wobble. This is most commonly a worn out steering dampner but could be loose/worn other parts including track bar, steering linkage, control arms, or suspension out of alignment.
Mike R
"Got Groceries"
88 Jeep Wagoneer
MJR is offline   Reply With Quote
Unread 06-28-2009, 10:23 AM   #4
jjg214
the steering linkage is VERY loose, i can swivel it by hand. so i suspect this is the problem, but when i tighten it, nothing happens it stays just as loose, so i guess the joints at the ends are broken? i believe the name of the part im talking about is the drag link.
Unread 06-28-2009, 10:38 AM   #5
MJR
It's not unusual to be able to rotate it by hand (some resistance) but you can see where the play is when someone else turns the steering while you watch. The one from the steering box to RF is the drag link and the other the tie rod.
"Got Groceries"
88 Jeep Wagoneer
Unread 06-29-2009, 03:20 PM   #6
jjg214
its the tie rod then, it can be moved with 0 resistance and we tried to tighten it up, without success.
