Wj swap using Jk tie rods? - JeepForum.com
post #1 of 3 Old 06-12-2013, 06:18 PM Thread Starter
Mike934
I've read these have the same taper as the stock wj stuff correct? Wj stuff also matches xj stuff.
But from my understanding, the Jk ends were bent different to clear the diff? I e also seen many issues with the. Wj swap, or the tie not clearing the diff? So curious here, maybe the Jk ends could be kept?
Yes I want to keep tres, no heims! Staying UTK I think..I'm only at 3.5" of lift.
Overlanders do it over land via overlanding because they like to overland?
Mike934 is offline
post #2 of 3 Old 06-12-2013, 07:47 PM
alexrule123
alexrule123's Avatar
The wj tie rods are bent to clear the diff. The only place mine hit are at full lock on the passenger side sway bar mount.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #3 of 3 Old 06-12-2013, 07:48 PM Thread Starter
Mike934
What diff cover? Ad your using UTK wj ends? Or otk?
Mike934 is offline
