WJ leather seats in XJ - JeepForum.com
post #1 of 8 Old 08-03-2008, 01:18 PM Thread Starter
Robahr24
Anybody think a WJ rear seat or front leather seats will fit in a xj? The leather WJ ones are more comfortable thats why I'm asking. Also, are the newer WJ's have rear flip down seats?
Robahr24 is offline
post #2 of 8 Old 08-03-2008, 01:21 PM
Bullseye
The front WJ seats should swap in, and I think you are suppposed to drill and extra hole or two in the back for the backseats to go in
http://www.jeepforum.com/forum/f11/seats-553020/
Bullseye is offline
post #3 of 8 Old 08-04-2008, 06:09 AM Thread Starter
Robahr24
what if there heated seats? Can you just splice the wires into the old switches if the cherokee had leather seats too?
Robahr24 is offline
post #4 of 8 Old 08-04-2008, 09:18 AM Thread Starter
Robahr24
And can you still use the power motors or will they be manual after you do this?
Robahr24 is offline
post #5 of 8 Old 08-04-2008, 10:12 AM
oldmanriver
With a little ingenuity I dont see why not, but I bet it'll be a little more complicated than soldering afew wires...
Make sure you do a write up if you do go for it, wj seats are on my to-do list as well, I just wasnt planning on power/heated. Good luck
'98 xj: 3.5" RE, 31's, nates front bumper, etc etc...
'90 xj: Wrecked, waiting for the day it can become a full blown trail rig.
'00 wj SOLD (still in family)
oldmanriver is offline
post #6 of 8 Old 08-04-2008, 10:35 AM
GrayBomb
1989 XJ Cherokee
WJ seats do fit and you can keep the power. The heat does work but its on or off so you may want to use a relay setup and only allow the heat to be on when the key is on.
Here is my thread.
http://jeepforum.com/forum/showthread.php?t=477556
For Sale: 89' Limited w/ Renix. Performance:Custom Cold Air Intake, Air Temp Conversion, Map Adjuster, Throttle Body Conversion Bored, 99+ intake manifold, 98 injectors w/ 99 fuel rail, bumped fuel pressure, Borla Wrapped Header, 2.5 in exhaust header back, open loop cooling, electric fan conversion, SS brake lines, 96+ brake booster and still getting 20 mpg highway
GrayBomb is offline
post #7 of 8 Old 08-04-2008, 10:59 AM
pipehitter155
i know ZJ seats bolt right in to an XJ, don't know about a WJ...
pipehitter155 is offline
post #8 of 8 Old 08-04-2008, 11:47 AM
Bullseye
Ok so after going through some of those threads, since I have a 98 XJ and am trying to swap in WJ seats will they bolt right in or not?
Bullseye is offline
Leather Seats for 300 00xj54 XJ Cherokee Technical Forum 2 04-03-2006 02:47 PM
Leather Seats 00xj54 XJ Cherokee Technical Forum 8 01-05-2006 09:28 AM
Leather Seats JeepDrivr93 XJ Cherokee Technical Forum 5 10-18-2005 08:44 PM
Leather Seats mission-inc XJ Cherokee Technical Forum 4 11-26-2004 11:06 AM
Leather Seats weldon XJ Cherokee Technical Forum 7 12-02-2002 10:56 AM
