Wiring Problem - JeepForum.com
post #1 of 5 Old 07-11-2013, 06:08 PM Thread Starter
bangoskank
Wiring Problem?
I will start with the symptoms:
-AC fan doesn't come on
-none of the window switches work
-radio display is off
-parking brake light is on, on the dash
-turn signals do not work but start to come on when I hit the brake
-when I shift out of Drive, I hear a constant rattling noise
This happens every once in a while recently. I turn the ignition off and restart it, and all is well again.
Seems to be a wiring issue. I looked around for burnt wires, blown fuses, etc. I know very little about these things and am just wondering if anyone can offer any more insight on the problem.
Thanks.
bangoskank is offline
post #2 of 5 Old 07-12-2013, 05:43 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Shoulda started with the year........
Good chance the big brown wire at the ignition switch is melting.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 5 Old 07-12-2013, 02:51 PM Thread Starter
bangoskank
It is a '99.
I will look at that though. Thank you
post #4 of 5 Old 07-12-2013, 02:59 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Originally Posted by bangoskank View Post
It is a '99.
well then, my advice is no good then. It applies to the earlier models.....
post #5 of 5 Old 07-12-2013, 05:24 PM
RacerX
1989 XJ Cherokee
Check, and clean all your grounds.
unbolt, wire brush, wire wheel, scrape, all the bolted ground connections and coat them with a silicon spray or even spray paint (to keep connection clean)
under the hood and under the dash.
This could fix the problem (I've seen loose/bad ground do stuff like what you are saying), it not it will probably help something, certainly won't hurt anything.
While you are under there, you may want to leave the radio on in case you wiggle some wires that are causing the prob.
4-wheeling is about going where others can't won't or don't think it's safe.
Freedom. Exploring the wilderness, or nature, whatever... - NOT paying to go on someone's roller-coaster ride, or go-cart track!
"The price of freedom is eternal vigilance." - Thomas Jefferson
RacerX is offline
