Wireless under carriage cameras - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Wireless under carriage cameras
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep seats at Jeephut.comEngo winches available at www.rockridge4wd.com! Free shipp
Unread 02-10-2014, 03:39 AM   #1
JAlVl3Z
Here is a project that kept me busy for a while. Ive been hunting for a wireless video streamer and finally found 4ucam.com.
-2 front facing cameras with leds for night
-mounted onto xfer case skid and covered with 3/8ths inch steel plate
-cameras turn on with rear defrost switch. Meaning they turn off with key and dont turn back on till I hit the button again.
-Wired single momentary pulse to latched on/off output from brights. The cameras switch with a flash of the brights.
- sent to wireless transmitter from 4ucam.com
-finally runs to tablet on an app called Findoo Wifi. The app allows recording of pics and videos.
JAlVl3Z is offline   Reply With Quote Quick reply to this message
Unread 02-10-2014, 12:43 PM   #2
Jeepfordan
This is awesome
1998 XJ- 4.0/AX-15/231- 3.5" RE. 4.10 gears - 4.6 build in progress.
Jeepfordan is offline   Reply With Quote Quick reply to this message
Unread 02-10-2014, 03:30 PM   #3
Motorcharge
I know more than you.
Motorcharge's Avatar
1991 MJ Comanche
I think keeping mud and **** off them is going to be the biggest problem, but definitely a cool idea.
Motorcharge is offline   Reply With Quote Quick reply to this message
Unread 02-10-2014, 07:54 PM   #4
K-R
Subscribed!
'bout all I know... minin' coal.
K-R is offline   Reply With Quote Quick reply to this message
Unread 02-10-2014, 09:29 PM   #5
sAe23
1995 XJ Cherokee
Isn't there some better place/way to mount them so you don't lose 3" of ground clearance?!?
Otherwise, cool!
sAe23 is offline   Reply With Quote Quick reply to this message
Unread 08-18-2014, 03:03 AM   #6
JAlVl3Z
Otherwise, cool!
Yeah, I see it as laziness, though smashing the hell out of it this summer vs it's use proved to be worth it.
Unread 08-18-2014, 01:25 PM   #7
sAe23
1995 XJ Cherokee
So? Any saved videos??
