Wipers won't work - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Wipers won't work
Spartan Locker's at all time LOW exclusive from ROCKRIDGE FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Bds fox ipf 2.0 racing series shocks now available at rock
Unread 03-04-2013, 04:10 PM   #1
EnderAZ
Wipers won't work
I've read through 13 pages of wiper complaints on this forum. Damn near all of them complain about intermittent or erratic wipers. Mine just don't work at all. I've checked all the fuses and the fuses look fine. One thing I noticed is that my hazards aren't working either. Do you know if the wipers and the hazards are on the same relay? I inherited this XJ and it came with other problems too. At first none of the blinkers worked either and it had a key stuck in the ignition. I ended up just replacing the whole steering column with another one that I got from ebay and now my blinkers work again, but I still don't have wipers. Any ideas?
EnderAZ is offline   Reply With Quote Quick reply to this message
Unread 03-04-2013, 08:25 PM   #2
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Any idea what year your XJ is? They're not all the same.
Originally Posted by chris87xj View Post
If you own a Renix Jeep, you'll want to check this out. >
An index to over 25 write-ups can be found in Post #1.
Cruiser's Mostly Renix Tips
My Jeep Technical Photos
http://www.cherokeeforum.com/g/album/1725214
cruiser54 is offline   Reply With Quote Quick reply to this message
Unread 03-05-2013, 10:34 AM   #3
EnderAZ
Whoops, sorry about that. It's a 93 XJ, 4.0, manual transmission, 4 door.
Unread 03-05-2013, 03:51 PM   #4
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Hopefully someone with a factory owner's manual showing the fuseblock will post it up for ya.
Unread 03-05-2013, 07:54 PM   #5
EnderAZ
I've already checked the fuses and they seem to be fine.
Unread 03-05-2013, 07:57 PM   #6
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Usually uses a circuit breaker and not a fuse. Does your fusebox look like this?
Unread 03-05-2013, 09:16 PM   #7
EnderAZ
Yes it does.
Unread 03-05-2013, 09:22 PM   #8
EnderAZ
Also you just answered my question. Mine is missing the circuit breaker. I kept glancing at that slot wondering what the hell it was and if it was my problem. Then I thought to myself "No, my wife's grandfather wouldn't have just taken it out and threw it away"..... I guess I should have known better with all the other items he's jimmy rigged on this thing.
Unread 03-06-2013, 04:45 AM   #9
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Here's a better diagram.
