Wiper Delay Module - JeepForum.com
post #1 of 3 Old 02-13-2005, 02:33 PM Thread Starter
Wiper Delay Module
Does anyone know where the Wiper Delay Module is located on a 96 Country? Wipers work fine if they're on low or high, but as soon as I turn them off they hang up. Thanks for the help.
93, 96, 01 XJ's
johnny3jeeps is offline
post #2 of 3 Old 02-13-2005, 04:57 PM
Tejas Raz
Yes, well at least on a 95 Sport.
Look down to the under-dash panel (above your legs).
It is velcroed onto the back side about between the light switch and the steering column.
L/S <----------|----------> S/C
It is about 2"w, 3"l, by 1" thick if it's like the one in my hand that I think is bad. AutoZone doesn't carry it, so I'll check the Jeep dealer tomorrow.
My Cherokee's wiper/washer action is totally intermittant. Sometimes it works, sometimes not. Haven't figured it out yet. And I need a skinny #20 torx screwdriver which I don't have to take off the steering column plastic to get to the "multi-function switch" to read out the wires there too. My big problem is that the inspection is past due now and wipers are a required item... dangit!
95 Cherokee 4dr 2 WD 4.0-Six Auto
Tejas Raz is offline
post #3 of 3 Old 02-13-2005, 05:38 PM Thread Starter
Delay Module
Thanks for the response. To get at two of those 3 screws on the steering col. will require a thin shafted #20 torx screwdriver at least 6 in. long. Shouldn't be too exspensive, a couple of bucks. I just had my IP out to change light bulbs and I found that out the hard way. Also, when you get ready to pop the IP loosen the screws that hold in the light switch and the cig lighter. Good luck
93, 96, 01 XJ's
Intermittent Wiper Delay Module futurefd XJ Cherokee Technical Forum 0 07-30-2009 09:42 PM
No Wiper Delay? chilipepprflea XJ Cherokee Technical Forum 10 06-07-2009 03:25 PM
Headlamp Delay Module xjguy98 XJ Cherokee Technical Forum 4 02-23-2008 12:12 AM
wiper delay module location? sjrider XJ Cherokee Technical Forum 2 01-03-2007 07:55 PM
Can anyone identify the windshielf wiper delay module in this picture? NewtooJeeps XJ Cherokee Technical Forum 5 11-13-2005 12:10 PM
