Windshield Wipers run on 'low' in delay - JeepForum.com
post #1 of 4 Old 01-23-2012, 04:29 PM Thread Starter
jrooneo
Hi, I have a 95 cherokee and she has been having some electrical problems lately. Recently the wiperblades will run on any delay setting as if it were the 'low' non-delay setting. At first it would run for 10 swipes on 'low' before going to the correct delay setting. Now they just stay non-delay. Any suggestions? Aside from speed setting they operate fine.
jrooneo is offline
post #2 of 4 Old 01-23-2012, 05:31 PM
billb2011
My '99 does that and I was told that the delay switch is in the wiper motor itself, so you either have to put a new motor in or live with it....I chose the latter.
"If you lend somebody $20 and you never see that person again, you might consider that money well spent." ~unknown
billb2011 is offline
post #3 of 4 Old 01-23-2012, 05:51 PM
Callelle
1997 XJ Cherokee
Replace the motor, it's what happened to mine.
Callelle is offline
post #4 of 4 Old 01-23-2012, 06:13 PM
KF4SQB
1994 XJ Cherokee
The '99 may be different, but the older XJ's delay control isn't in the wiper motor. Its in a small box that mounts with velcro to the front of the lower dash trim panel on the driver's side. Its a small box, app. 1 1/2 X 2 X 3 (working from memory here), with a wiring harness plugged in on each end of it. I'll practically guarantee that this small box is your problem, as it houses all the electronics for the intermittent function.
4-wheeling: because football, basketball, baseball, and golf only require one ball!
Confidence: The feeling you get just before you fully understand the situation!
KF4SQB is offline
electrical , wipers
Wipers have only HIGH, no low or delay, and they don't "park" PUNISHER_VETTE XJ Cherokee Technical Forum 15 05-01-2014 11:49 AM
Delay Wipers Holder350 XJ Cherokee Technical Forum 3 07-26-2010 01:32 PM
Installing delay wipers? Hussler XJ Cherokee Technical Forum 3 01-06-2010 11:24 PM
??? power locks, delay on wipers, vents and cruise control....all doesnt work!!! Elliottm2333 XJ Cherokee Technical Forum 4 03-11-2007 06:29 PM
windshield wiper delay?? thebubba1018 XJ Cherokee Technical Forum 6 02-27-2005 08:23 PM
