Quantcast Windshield wiper fluid stopped working on front only? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Windshield wiper fluid stopped working on front only?
Old 03-19-2010, 07:15 AM   #1
burton1488
My windshield wiper fluid does not spray on the front windshield anymore, it still works in the back though so the pump is fine and I am not out of fluid. Anyone know what would cause just the front to stop spraying?
burton1488 is offline   Reply With Quote
Old 03-19-2010, 07:55 AM   #2
cruiser54
1990 MJ Comanche
There are 2 separate pumps. Have someone actuate the front washer switch while you listen near the washer bottle for the pump running.
cruiser54 is offline   Reply With Quote
Old 03-19-2010, 09:28 AM   #3
Apostle
you can swap hoses to see if the line is clogged but the pumps have differant connectors so cant swap to check switch. you can take the connector off and measure the voltage going to it with the switch on (not sure what reading you should get)
pumps are >$10 at the auto parts store
2011 JK Wrangler - Sahara Tan SOLD
2012 JKU - White
Apostle is offline   Reply With Quote
Old 03-19-2010, 10:29 AM   #4
Kettles
Kettles's Avatar
I dont know which pump is on top, but if the fluid is low enough, only one will spray. Add some fluid and find out!
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output Pictures Build Thread
"Live Free Or Die; Death Is Not The Worst of Evils."
-General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline   Reply With Quote
Old 03-19-2010, 10:35 AM   #5
burton1488
thank you, I will be trying to figure it out tonight after work. I will let you know how it goes and what was wrong.
fluid, windshield, wiper
Glock Forum
