Windows, mirrors, locks problem - JeepForum.com
post #1 of 5 Old 12-25-2012, 07:51 PM Thread Starter
NaPeer
Hi all, let me tell you my problem. I have a 2000 Cherokee which I love. Within a week after buying it, the passenger side window would intermittantly stop working when controlled by the passenger. Driver side control of that window would still work. Thought it might be the window lock switch going out. This issue would come and go. Then about a month later, the ability to operate any window from any door stopped, including driver side controls and window. Then the ablility to operate the power door locks from the driver side quit. The light on the driver side door switch is out. The passenger side door switch light is on and I can operate the door locks from that door panel. The keyless remote still operates the locks. In addition, I can not operate the mirrors from the driver side panel. No noise or clicking.
I am thnking that this is an electrical issue, a wire or wires broke or shorting out. I am not electrically savy so any help in getting started will help. Do I just perform a visual inspection of the wires and connections? Do I use a multimeter? What should I look for first? Thanks Jeep owners
NaPeer is offline
post #2 of 5 Old 12-25-2012, 08:28 PM
Agent 000
Agent 000's Avatar
Sounds like your driver's side door switch assembly gave up the farm. The're not too hard to change out, had to change one out on my 2000 XJ before.
Heritage Region Jeep Alliance
Chili Pepper Red 1998 Jeep Cherokee Classic
Agent 000 is offline
post #3 of 5 Old 12-25-2012, 10:26 PM
OnTheFence
You'll need to open the door panel, and possibly remove that entire wiring harness.
It goes from the inside door, behind the speaker, and into the door boot, and plugs into the kick panel wiring harness clips.
If you can remove the entire wiring loom, it will be easy to test for continuity and butt splice the busted wires, if any.
Google around.
OnTheFence is offline
post #4 of 5 Old 12-25-2012, 10:54 PM Thread Starter
NaPeer
Thanks for the info on the harness. I'll pull it and check it out.
NaPeer (No Equal)
NaPeer is offline
post #5 of 5 Old 12-26-2012, 07:11 PM
ConradThomaier
I just replaced the driver's door module in my 2000 Cherokee. Very easy to do. A Dorman DDM was $66.03 with shipping from Rock Auto. See http://www.rockauto.com/catalog/more...919&cc=1363384.
The new DDM has a working door lock safety button, so I undid the wiring bypass. I believe you'll need to re-program the remote door openers as they are programmed to work with "a" specific DDM.
ConradThomaier is offline
