window regulators fix?? - JeepForum.com
post #1 of 9 Old 01-03-2012, 01:23 AM Thread Starter
queball1989
my 99 xj only has one window that works (drivers side front)
it really doesn't bother me, because mine still works but I want to be able to put all my windows up and down.
Anybody got any suggestions about how to fix the regulators?
queball1989 is offline
post #2 of 9 Old 01-03-2012, 12:19 PM
AZ Jeff
2014 JK Wrangler
What exactly is wrong with your windows? Please describe the behavior.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 9 Old 01-03-2012, 12:52 PM Thread Starter
queball1989
well the windows dont work period, dont go up or down, but you can hear the motor in the window working but they don't move at all. im thinking about just taking the parts out of my friends junked xj
post #4 of 9 Old 01-03-2012, 02:11 PM
darkstar06109
2009 WK
Cherokee window regulators are kind of a weird design, I work for a glass company and have seen alot of them. Have you taken the door panels off to see if the window is still connected to the regulator? If it is still connected its a good bet that the gear on the end of the motor is striped out and not moving the regulator up and down. I just had to replace my two front regulators. I managed to pick both of them up for $30 each. They are pretty easy to install just 3 or 4 10mm bolts if i remember correctly
darkstar06109 is offline
post #5 of 9 Old 01-03-2012, 05:45 PM Thread Starter
queball1989
I know that the passanger side has been taken apart and rigged multiple times but I'm not sure if it's the regulator or not but I believe the gear is stripped
who woulda thought, all English majors are drunks, and perverts"
post #6 of 9 Old 01-05-2012, 07:48 PM
JWELK
Sorry to tell you this, but this is the worst design ever. It is the "regulator" the motor drives a flexible shaft that raises and lowers the window. There are repair kits available on ebay. But it depends on how yours is broken. If the plastic shaft has separated from the motor housing, I think you are sunk. I've seen them on ebay. OEM down here(PR)was close to 300 as I recall. Be very careful installing the new one, the shop here bent it too tight and broke the new one. He bought the second one.
Regards,
Jim W
JWELK is offline
post #7 of 9 Old 01-05-2012, 08:42 PM Thread Starter
queball1989
Haha yeah no kidding. I can't figure out why Jeep would want to use a part like that but it is what it is ill be sure to use caution putting the new ones in, but I'm just going to jack the parts for all the windows(hopefully) instead of spending 300 bucks on a part that's probably going to break anyway
post #8 of 9 Old 01-05-2012, 09:16 PM
Saudade
1988 XJ Cherokee
Saudade is offline
post #9 of 9 Old 01-09-2012, 11:20 AM Thread Starter
queball1989
Originally Posted by Saudade View Post
thanks I'll definitely have to take a better look at them!
Window regulators muddd XJ Cherokee Technical Forum 9 11-01-2010 03:14 PM
I HATE XJ Window Regulators midfat XJ Cherokee Technical Forum 3 04-19-2008 09:34 AM
Manual window regulators rcpilot92 XJ Cherokee Technical Forum 1 12-05-2006 11:12 AM
Window Regulators scotty'98 XJ Cherokee Technical Forum 7 04-06-2005 09:05 PM
Window Regulators dryflie XJ Cherokee Technical Forum 2 08-19-2003 10:46 PM
