Window crank arm removal - JeepForum.com
post #1 of 13 Old 05-22-2004, 11:18 AM Thread Starter
Mikey B
I'm looking to replace my front speakers but I can't seem to get the window crank arms off...
I've read the haynes manual and there is nothing in detail... I have done it before on a ford but I don't see the "clip" on the Jeep
TIA
Mikey B
95 XJ | Sport | 5 Speed | 2 Door | 4.o
31x10.5 BFG A/T TA's | 31x11.5 Thornbirds | 30x9.5 Bridgestone A/T
RE 3.5 Super Flex | Front and Rear receiver hitches | Rocky-Road BPE's and Rock Rails | 48" High lift
Hella 500's | Hella Micro FF | "Walmart light bar"
R.I.P.
Mikey B is offline
post #2 of 13 Old 05-22-2004, 03:02 PM
mbood82
mbood82's Avatar
if there is a plastic covering over the arm, see if you can pull it off. I seem to recall it might have a phillips head screw holding it on instead.
'99 Jeep Cherokee - RE 3.5" SuperFlex with 32s
'06 Dodge Magnum R/T
'03 Toyota MR2 Spyder
mbood82 is offline
post #3 of 13 Old 05-22-2004, 04:17 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
To remove the window cranks, just pull them straight off. Grab them at the mount point (where the arms attach to the door) I partially slid my fingers behind it and just jank the hell out of it.
Some vehicles used a small C clip that requires a special tool, but my 93 didn't and I have never heard of anyone else needing one either.
My arm rests had two philips screws to hold them on. Remove those screw and rotate the entire arm est up till the top piece pops out. There are some notches on that piece, rotating the arm is the only way to pop it out.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #4 of 13 Old 05-22-2004, 08:32 PM
JeepenCher
Yah that is really al i've had to do and i have replaced all of mine recently and have taken them of repeatedly since.
JeepenCher is offline
post #5 of 13 Old 05-22-2004, 09:32 PM
truckerdirt
you could also use a flat head screwdriver to pop off teh crank handle if you can't get your fingers in there. i have yet to find one that had the clips; and haynes manual says to use a screwdriver to pop them off.
truckerdirt is offline
post #6 of 13 Old 05-23-2004, 11:55 AM
DefaZ
DefaZ's Avatar
mine has the metal clips, and all you do is slide a flathead under there and pop the clip out [sounds gangster eh?].
On mine at least, just pulling them off would break them.
DefaZ is offline
post #7 of 13 Old 05-25-2004, 12:56 AM Thread Starter
Mikey B
Thanks guys
This place is a wealth of knowledge
R.I.P.
Mikey B is offline
post #8 of 13 Old 11-09-2005, 09:49 AM
oldbastard
Not to be a me too post but my 97 also had the metal clips. It is hard to see so shine your flashilight in there and use a small flat head to pop the clip off. One warning do this in your garage with a clean floor because the clip may fly off and you will spend forever looking for it. After I removed the clip the window crank came right off.
oldbastard is offline
post #9 of 13 Old 11-09-2005, 09:58 AM
conrasm
conrasm's Avatar
My passenger side tends to fall off when the door is slammed. Is there something I can do to fix it or will I need a new handle. If so i think I can live with the loose crank handle.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #10 of 13 Old 11-09-2005, 10:13 AM
oldbastard
Conrasm,
If your window crank falls off that easily I would guess you are missing the clip that holds it on. If your driver side stays on it probably has the clip. I would suggest you remove the clip on that side and take it to the auto parts store to find a replacement for the passenger side. Maybe buy a few extras in case they go flying when you put it back on.
On my 97 if I left off the clip I could easily pull the crank off so that's got to be what your problem is. Go Steelers!
post #11 of 13 Old 11-09-2005, 10:34 AM
gumcrew2
1991 XJ Cherokee
Mine both broke off so I use one I got at the junkyard. I just hand it to the passenger to roll up/down their window. lol.
"Nitrous? So is that like viagra for your Jeep?" -mom
"I flopped it"
gumcrew2 is offline
post #12 of 13 Old 11-09-2005, 02:36 PM
lectrode
lectrode's Avatar
1987 XJ Cherokee
Take a rag and put it behind the crank handle base and work it like you
would polish your boots. The clip comes right off.
lectrode is offline
post #13 of 13 Old 11-09-2005, 07:21 PM
fryed_1
Put a couple peices of paper behind it as you shove it on maybe? That's what I did for one of mine and it hasn't had any problems popping off.
'94 XJ - 8" Long arms, 9" rear, 35's
'89 Waggy
'48 Willys
fryed_1 is offline
Window crank handles Dragnz24 XJ Cherokee Technical Forum 3 04-27-2007 07:30 AM
Help me this morning please: Window CRANK removal... ne_plus_ultra_1 XJ Cherokee Technical Forum 13 11-14-2006 06:23 PM
Crank Sensor Removal?? Lazlow XJ Cherokee Technical Forum 4 10-10-2006 02:53 PM
94 Cherokee Window crank JBACA XJ Cherokee Technical Forum 2 05-12-2005 01:03 PM
Window crank phaeton XJ Cherokee Technical Forum 3 02-15-2005 07:52 AM
