Quantcast Winch And Battery?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Winch And Battery??
FREE shipping on Rugged Ridge Soft tops @thejeephut.comGR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 08-02-2008, 03:52 PM   #1
CG98XJ
Winch And Battery??
Going To Order A Winch Soon. Im Wondering If I Should Run It Off My Current Stock Battery Or Install A Second Battery To Run The Winch. What Would Work Better?
CG98XJ is offline   Reply With Quote
Old 08-02-2008, 04:17 PM   #2
Magus2727
Magus2727's Avatar
1995 XJ Cherokee
a new bat. would always help, its not going to harm any thing
NAXJA Member #2619
1995 Jeep Sport Cherokee 4x4 with an Auto and 4.0L
B&M Transmission Cooler and Autometer Tranny Temp Gauge, Ruff Stuff Diff Cover on D30.
Taraflex 1.5" BB (rear shackle only), HD Quadratec leaf springs, RE 3.5" front springs, OME Long shocks, JKS Adjustable Track Bar from K.O.R.
Daystar Control Arm Bushings, Bushwhacker Flairs, Rhino lining along bottom trim, AGR PS pump with Cooler & Filter.
Bored TB, APN Manifold, New Downpipe, Magnaflow High Flow Cat, Flowmaster Super 44.
Dual Oil Relocation Kit running two K&N301 size filters, Autometer Digital Cobalt Oil Temp and Oil Pressure Gauge.
Magus2727 is offline   Reply With Quote
Old 08-02-2008, 04:25 PM   #3
Arcticcat843
dakuda is a god
Arcticcat843's Avatar
1980 CJ5
optima deap cycle ftw!!! I have a red top. They are hard to kill. i have heard that the blue top ones have a better warrenty though....Oh and if you are doing long pulls you are going to KILL you hole electrical system. That winch is going to be a HUGE strain on it. Just use it smartly and you will be fine. Oh and if you really want to go all out and have deap pockets run a dual battery set up with a high output alt.
Arcticcat843 is offline   Reply With Quote
Old 08-02-2008, 04:27 PM   #4
tupton
You will need a deep cycle battery for your winch. A stocker can't handle the draw from a winch.
Let's Go Mountaineers!!
Jeepinwv.com
West Virginia's Original Jeep Club
tupton is offline   Reply With Quote
Old 08-02-2008, 04:38 PM   #5
CG98XJ
Sounds Good. Ill Probly Get A Optima Red Top. Thnx For The Input Guys
Old 08-02-2008, 06:32 PM   #6
1offroadin4x4
I've got a duralast 800 cca on mine w/ a 12000 # mile marker and never misses a beat. Battery only costs about $80.00. Sat all winter...died, charged it and keeps on tickin' !!!
1offroadin4x4 is offline   Reply With Quote
Old 08-02-2008, 06:40 PM   #7
CNY
Wrong. A stock battery will work just fine. Use it until you need something new.
Originally Posted by Arcticcat843 View Post
optima deap cycle ftw!!! I have a red top...
Wrong. (half-wrong?)
If you have a red-top, you don't have a deep-cycle. All of Optima's deep-cycles are blue or yellow topped. BUT, not all blue or yellow tops are deep-cycle! I made that mistake when I bought a blue-top that is merely a starter battery with dual-terminals (34M Marine Starter, instead of starter/deep cycle).
...Oh and if you are doing long pulls you are going to KILL your whole electrical system. That winch is going to be a HUGE strain on it. Just use it smartly and you will be fine.....
RIGHT! (Hey, I'll give credit where credit is due! )
CNY is offline   Reply With Quote
Old 08-02-2008, 07:45 PM   #8
black2door
HAHA
black2door's Avatar
1997 XJ Cherokee
I run mine on a stock like battery. Works fine, Im just gonna run it that way till it dies and then get an Optima (either yellow or blue top)
-Andrew
Another Chero in progress
black2door is offline   Reply With Quote
Glock Forum
