Will these rims fit my XJ??? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Will these rims fit my XJ???
April Savings Save 5% Off Of Jeep HeadlightsBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiSave on Rancho Products !
Unread 08-09-2012, 10:27 PM   #16
rugsucka
I had my 235's and 31x10.5's on 15x7's
Had to get wider rims to properly run 12.5" tires though - 7" will cause 'crowning' at good pressure and potential lower tire life if running at lower pressure to flatten the tread.
15x8 is the standby for 12.5" tires. General rule is not more than 4" difference.
If you decided to future proof yourself, you can run 235's on 8" rims and they will look wide, but you would not want to air down below 15psi or risk slipping a bead. Your 31x10.5" tires will also mount well on 8" rims with similar watchouts for low pressure. I generally only deflate to 15psi anyways due to an under powered air compressor, but do just fine.
'00 XJ - Scampy the XJ
'10 Ram 1500 - Scampy's TB
rugsucka is offline   Reply With Quote Quick reply to this message
Unread 08-09-2012, 10:44 PM   #17
straightsixjeep
Whether I go with 15x7s or 15x8s, will 235s not rub even with 0mm offset rims? That about sums up my questions. Also, those d windows are being sold by summit racing but on ebay, so their quality rims and I get more ebay feedback!
straightsixjeep is offline   Reply With Quote Quick reply to this message
Unread 08-10-2012, 04:43 AM   #18
Red82
1997 XJ Cherokee
Back spacing is really more of the issue with Jeeps than offset. They're related but different.
Red82 is offline   Reply With Quote Quick reply to this message
Unread 08-10-2012, 10:19 AM   #19
gcy24
is there problems when switching from stock hub centric to aftermarket lug centric?
1999 Cherokee classic- 3" RC lift with 31" Firestones.
selling "snowflake" 15x7 wheels with 225/75/15 tires, pm me.
gcy24 is offline   Reply With Quote Quick reply to this message
rims
