Will these rims fit my XJ??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Will these rims fit my XJ???
Only 2 Days left to win $3,800 Jeep Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention seahawks fans!!! Want to save some $$$ ??!!
Unread 08-08-2012, 07:28 PM   #1
straightsixjeep
Hey guys Im looking for new tires and rims for my 98' xj sport. Will these rims fit on the cherokee? http://www.ebay.com/itm/Cragar-Black...ht_1621wt_1163 If they will Il order those along with these tires - http://www.tirerack.com/tires/tires....cleSearch=true
Let me know what you think, if they will work Il order them. Thanks guys
straightsixjeep is offline   Reply With Quote Quick reply to this message
Unread 08-08-2012, 09:29 PM   #2
straightsixjeep
any input is appreciated
Unread 08-08-2012, 09:34 PM   #3
Paradise XJ
1988 MJ Comanche
Yes. If you're not using 12" wide tires, they're fine. Good for 31x10.5's. Big ol' boggers might need a wider bead.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline   Reply With Quote Quick reply to this message
Unread 08-08-2012, 09:41 PM   #4
straightsixjeep
Thanks for the reply. Id be putting the general 235-75-15s on it so it should fit fine. Last question before I order them, they say 5x4.5 in the title but the description says the Bolt Pattern is: 5x114.3. Is that ok?
Unread 08-08-2012, 09:45 PM   #5
droz
1997 XJ Cherokee
it's ok 5 x 4.5" is the same as 5 x 114.3 mm
droz is offline   Reply With Quote Quick reply to this message
Unread 08-08-2012, 09:46 PM   #6
ltrail
1984 XJ Cherokee
Fwiw, jegs.com and summitracing.com have them also. Comparable prices and more width and offset options. Jegs even has a nifty model program to see desired wheel on your vehicle with your tire size and lift to an extent.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline   Reply With Quote Quick reply to this message
Unread 08-08-2012, 09:48 PM   #7
ltrail
1984 XJ Cherokee
some metrics and standards work together
Unread 08-08-2012, 10:01 PM   #8
straightsixjeep
Awesome good info ltrail. Trying to decide if I want black on black or if I should find chrome/silver rims. Il just keep looking
Unread 08-08-2012, 10:16 PM   #9
ltrail
1984 XJ Cherokee
try the setup on jegs.com man. There are many other cragar wheels out there. One set it like a big star, they a 5 spoke steel wheel. 541 series or something. Its cool to be able to see the wheel/tire combination before purchase.
Unread 08-09-2012, 03:05 PM   #10
straightsixjeep
That program on jegs was awesome, I spent a good hour on there trying all the different rims. Im still liking the d window rims however may go with american racing over crager, these ones - http://www.ebay.com/itm/330772589148...ht_1643wt_1163
They are 15x7 5x4.5, 4in back spacing and 3.3in center bore diameter. Will I be able to run these with 235-75-15's no problem? Im talking about no rubbing? Thank you
Unread 08-09-2012, 09:23 PM   #11
ltrail
1984 XJ Cherokee
You should be good with that size and spacing. That price is ugly though, free shipping or not those are pricy. Did you look at jegs prices lol? Or just get distracted by the car chart?
Unread 08-09-2012, 10:13 PM   #12
rugsucka
Basically the same rim is 40 bucks a piece at summit 191 shipped - 41 bucks a piece. You need not spend that much.
I'd also consider the 15x8 options. They will be fine with your 235's if you don't super air down, and if you ever go 12.5" wide you'll still be ok. Same price as well.
'00 XJ - Somewhat modified
'01 Venture - high mileage, paid for, shut it
rugsucka is offline   Reply With Quote Quick reply to this message
Unread 08-09-2012, 11:08 PM   #13
straightsixjeep
Haha you are correct I was distracted by the car chart. They have the rims I want for $55 a piece - http://www.jegs.com/i/Cragar/260/342...=751048#bottom They dont come with the center caps but thats ok. I know the price is high for the american racing rims on ebay but they have the offset I want. The cragers on ebay have a 6mm offset, where the pricey american racing have a 0mm offset (I want a wider stance). For $230 shipped I can get the crager d-windows with a 0mm offset - http://www.ebay.com/itm/Cragar-Black...ht_1588wt_1163
Unread 08-09-2012, 11:10 PM   #14
straightsixjeep
Thank you for the link. For now id be going with the 235-75-15s but when and if I can afford a lift kit, id be going up to 31x10.5x15s. Will those fit a 15x7 rim? Also wont rub as bad with 0mm offset compared to the 6mm offset.
Unread 08-09-2012, 11:21 PM   #15
ltrail
1984 XJ Cherokee
Kids get distracted by anything shiny these days lol! enjoy!
rims
