Which will provide better flex. IRO 3-link vs Treks Y-link? - JeepForum.com
post #1 of 29 Old 04-18-2010, 10:53 PM Thread Starter
Jeep89JV
Like the title states, I was very interested in buying an IRO 6.5" LA 3-link but I'm looking for quality in the long run. Would I be better off buying the Y-link through treks or would the 3-link IRO hold its weight?
I've read a good amount so far but seeking more opinions on this exact question.
Edit: My largest concern would be the fact IRO is considering going to only adjustable LAs, though they haven't yet. Where as Treks Y-link is adjustable.
If you don't stand behind our troops, feel free to stand in front of them.
My Build Thread:
New Mexico Driving Rules...
  • As a general rule, the vehicle most in need of a significant amount of bodywork (for which the driver is most likely uninsured) always has the right of way.
  • Never use directional signals when changing lanes. They only serve to give away your next move, causing most NM drivers to speed up and not let you in. In fact, use of directional signals within most large NM city limits is actual illegal.
  • NM law states that at least 50% of all paved surfaces within the state must be under construction at any one time. In all construction zones, at least half of the available lanes must be closed, regardless of whether any actual construction is be accomplished or not. Construction signs shall be regularly repositioned in order to warn drivers about upcoming lane closures immediately after they pass the last exit before traffic backups.
  • Driving through constructions zones with upcoming lane closures is a popular game in NM. Itís called the "speed up and pass as many cars as you can, then see how close to the lane closure you can squeeze back into traffic before hitting any of the orange construction barrels" game.
Jeep89JV is offline
post #2 of 29 Old 04-18-2010, 11:13 PM
Vassago
flex depends on a lot more than what LA's to pick
"He almost broke the land speed record in 1977, popular opinion amongst his team was that his beard caused to much wind resistance. He would have shaved itÖ No, no he wouldnít have."
MY BUILD THREAD:
My Photography
Vassago is offline
post #3 of 29 Old 04-18-2010, 11:20 PM Thread Starter
Jeep89JV
Assuming you were to use the same components with both of the LAs...I understand its not all on the arms.
My Build Thread:
Jeep89JV is offline
post #4 of 29 Old 04-18-2010, 11:33 PM
Crunch
Have you looked at the RK X-factor three link? I had this set up on my TJ. Was AWESOME. Out flexed the radius set ups others in my group had. Is super beefy to. Just throwing that option at ya.
New one-2000 XJ sport- Now has 3.5" lift, Hp 30/8.25 w/4.10's, V8 Zj steering
Totaled 3/18/10-'99 Black 2 door XJ DD, 3.5+" bastard lift.
SOLD-'98 TJ 4 banger 5 speed, 4.88's, Hp 30 ARB'd, S35 w/Detroit and truss, RK LA's, Kilby skids and LOTS of other junk. Should have kept it!
Traded for my XJ - '98 ZJ was pretty and built at one time- Hp30, 8.8 and 5" lift and other stuff.
Crunch is offline
post #5 of 29 Old 04-18-2010, 11:38 PM Thread Starter
Jeep89JV
Yes though its quite expensive considering if you are buying the Treks setup you also get good armor from their belly pan.
My Build Thread:
Jeep89JV is offline
post #6 of 29 Old 04-19-2010, 12:04 AM
xjhavens
Depends on what kind of money you want to spend. I've heard nothing but good things about both. I'd go with the treks, the selling point is the belly pan. Oh and the iro is not a 3 link, its a radius arm just like the treks. And non-adjustble arms a good if you are 100% you'll never have to move anything a 1/4 inch..ever!
xjhavens is offline
post #7 of 29 Old 04-19-2010, 12:22 AM Thread Starter
Jeep89JV
This is my dilemma. I have heard nothing but good things from both as well. Though for the money i'll be spending and plan on this being one of the final bolt ons for my suspension i'll be doing, I would like to not go the wrong route in the long run.
My Build Thread:
Jeep89JV is offline
post #8 of 29 Old 04-19-2010, 12:26 AM
Starboard M
For a bolt on front suspension of a Cherokee, both will flex the same.
Most long arms, regardless of 3, 4 or radius arms will flex the same. Other factors such as shocks, brake lines and trackbar become the limiting factor.
Originally Posted by NoVaHunter View Post
Honestly, its dicks like you that make unnecessary comments via the internet that have no impact what so ever.
Starboard M is offline
post #9 of 29 Old 04-19-2010, 05:43 AM
Muddeprived
Muddeprived's Avatar
IRO's will flex better. The 3-link setup doesn't have the binding that radius setups have.
By the way, if you call IRO, you can get the option for adjustable arms instead of fixed.
IRON ROCK OFF ROAD: XJ Critical Path Long Arm Upgrade
They have the option for the upgrade kit but I don't see it listed for the long arm complete kit but I'm sure you can get em to send you adjustables if you want em.
2001 XJ Sport 4.5" LA
1999 TJ 2.5L 5spd 2" lift
Muddeprived is offline
post #10 of 29 Old 04-19-2010, 06:23 AM
3fifty
The IRO kit is not a 3 link. The IRO Y Link Radius arms scare the poop out of me. The caster adjuster bracket that scares the hell out of me.
IRO is big in the WJ world and I run their track bar on my XJ but you couldnt pay me to run those links.
Run the TNT and when you get to buggy status build a 3 link.
3fifty is offline
post #11 of 29 Old 04-19-2010, 06:55 AM
Muddeprived
It's not?
NOW HIGHER CLEARANCE AND BETTER TIRE CLEARANCE! We use an exclusive, non-binding, 3 link setup that has a pair of front long arms that will flex more than you thought possible. You WILL NOT bend these long arms as they are made from 5/16" wall DOM tubing. The bushings at the unibody are greasable super-flex joints that pivot to give as much suspension travel as your shocks will allow. We combine that with factory style rubber bushings at the axle for superior road noise and vibration dampening. As always, this kit is 100% bolt on! NO WELDING and only minor drilling is required for installation. No adjustment is necessary in any part except for our unique caster adjustment bracket that allows 7.5į of adjustability; plenty for any lift height from 4.5-8"!!
It attaches to 3 spots on the axle, making it a 3-link but you can call it a radius setup if you wish cuz it's somewhat similar.
I've heard nothing but good feedback from xj owners running this kit. There doesn't seem to be any issue with the caster brackets and if you are iffy about em then you can just ask em to give you adjustable arms instead.
post #12 of 29 Old 04-19-2010, 07:19 AM
3fifty
A 3 link would have 3 separate links.
It is Y link radius arm setup with an upper y link removed.
Its identical to the TNT setup minus the upper on one side.
IRO
3fifty is offline
post #13 of 29 Old 04-19-2010, 08:37 AM Thread Starter
Jeep89JV
The caster adjust bracket scares many including myself, though with a thread over on NAXJA for IRO customers so far, with over 125 replies not a single person has complained or had an issue with it yet.
My Build Thread:
Jeep89JV is offline
post #14 of 29 Old 04-19-2010, 12:59 PM
Starboard M
Originally Posted by Muddeprived View Post
It's not?
It is a radius arm. By your logic, the Treks radius arm is a 4 link, you think that looks anything like the stock style suspension?
post #15 of 29 Old 04-19-2010, 01:39 PM
Muddeprived
Then someone outta tell Iron Rock Off road to stop calling their kit a 3-link. Until that happens, I'll continue calling it a 3-link.
TREKS XJ Y-Link Upgrade & Chassis Stiffener Holiday Sale TnTCustoms XJ Cherokee Technical Forum 0 11-17-2009 08:37 PM
Control Arm Dilema JKS or Treks Y-Link gunselman XJ Cherokee Technical Forum 2 09-09-2008 03:53 PM
link to homebrew sway bar link.......? expressfish XJ Cherokee Technical Forum 4 06-19-2007 02:41 PM
Y-Link arms not as good for flex??? rosader XJ Cherokee Technical Forum 12 04-05-2007 09:06 PM
Y-Link radius arm vs 4 Link and trackbar? Muddy Cherokee XJ Cherokee Technical Forum 2 12-26-2006 01:42 PM
