Will not start when warm - JeepForum.com
post #1 of 9 Old 09-06-2012, 06:12 PM Thread Starter
87manche17
1987 MJ Comanche
I went to the grocery store today in my 87 MJ, and when I started it while it was cold it started and ran fine. When I turned the truck off to go in the store I came back out and it wouldn't start. I got a ride home and let it sit in the parking lot for about an hour. I came back and it fired right back up. My conclusion is it will not start when warm, Ive already changed my CPS on the bell housing still no change. It has a new coil and control module so it cant be that. I'm thinking its the stator in the distributor, could that be it or something I haven't though of?
87manche17 is offline
post #2 of 9 Old 09-06-2012, 06:15 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
The stator in the distributor is certainly a primary suspect.
When they fail thermally (heat related), the 4.0 engine will continue to run on the latest signal from the stator, but when the engine is turned off, it won't start unless that component is giving valid input data to the computer.
I'd recommend you replace that component. Not particularly expensive and shouldn't be too bad to replace. Refer to a maintenance manual if you have one.
Good luck and keep us updated!
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #3 of 9 Old 09-07-2012, 10:47 AM Thread Starter
87manche17
1987 MJ Comanche
ok thanks
post #4 of 9 Old 09-07-2012, 12:00 PM
Cosmo13
I have an 89 xj and I had the same problem it ended up being my fuel pressure regulator. First start of the day it would start no problem but if I went anywhere and it only sat for a little bit I would have a hell of a time starting it. If it sat for a few hours it would start up no problem.
Cosmo13 is offline
post #5 of 9 Old 09-07-2012, 12:13 PM
ltrail
1984 XJ Cherokee
Try giving it half throttle and then cranking. Had a similar issues which was a Cts. Cts was bad and computer seemed to think the engine was cold thus dumping ton of fuel for cold starting. With pedal half way down it fires right up.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #6 of 9 Old 09-08-2012, 11:56 AM Thread Starter
87manche17
1987 MJ Comanche
My CTS is brand new so it cant be that. But im going to try the stator first and see what happens.
post #7 of 9 Old 09-08-2012, 04:46 PM Thread Starter
87manche17
1987 MJ Comanche
I installed a new stator and it did not help. Its still flooding itself out trying to start. I think I need to replace my MAP sensor but Im not sure.
post #8 of 9 Old 09-08-2012, 04:56 PM
tjwalker
tjwalker's Avatar
Map sensor can be tested with a meter and a manual (or procedure) And be sure that the vacuum line leading to the map sensor is pulling good vacuum.
Here is a link to an article that can be helpful in testing RENIX sensors.
http://www.lunghd.com/Tech_Articles/...iagnostics.htm
tjwalker is offline
post #9 of 9 Old 09-08-2012, 07:27 PM Thread Starter
87manche17
1987 MJ Comanche
Ok my CTS is not even hooked into the block itself. I thought the one on the back of the head was a "actual" sensor, so I didn't hook it up when i changed motors. Ill hook it up tomorrow and go from there.
My GC will not start once she's warm...? Keleios XJ Cherokee Technical Forum 9 08-29-2010 09:34 AM
Warm Start Problem MrAce XJ Cherokee Technical Forum 2 08-26-2010 05:02 AM
XJ hard to re start when warm qwikz XJ Cherokee Technical Forum 0 12-09-2006 08:03 AM
96 XJ Hard Start Warm craicrjack XJ Cherokee Technical Forum 3 09-13-2006 06:28 PM
Warm start problem 96 4.0 saxj XJ Cherokee Technical Forum 5 03-07-2006 05:36 AM
