#1 | |
Will my u pol peel?
I sprayed my floor. I scuffed and cleaned several times, sprayed two coats. Seems to be covered nicely but ive noticed everyone else has done 3 or 4 coats. I also did the ouside of my jeep and the rear fenders where i folded them is peeling and I know its because it was bare metal and I didnt use any etching primer. The sides were scuffed and cleaned. Sprayed two coats. Do you think the sides will peel also?
#2 |
How are the other areas you sprayed holding up?
I ask b/c I just sprayed my rockers and door jambs. I first removed trim, hit areas to be sprayed w/80 grit, wiped clean w/Acetone, masked areas I didn't want sprayed, then applied one full bottle to areas. ![]() ![]() Up next inside of doors, bumpers and I've been toying w/the idea of the spot on the roof where the corner of the windsheild/rain gutter meet. I'd prolly just spray the whole roof. Good idea or no?
99 XJ 4.0 D30 29sp 8.25, K&N, Kellys WIP main 5 wires 1AWG http://www.kelleyswip.com/price.html, Banks header, Stainless Magnaflow catback, cat, 2" OME lift JC1B Leafs, JKS quicker discos, 30X9.5X15 Cooper STT's, 62mmTB http://www.thefastman.com/Throttlebodies40.asp, Cibie E-codes with 55/60 Osram bulbs, Alpine 7563 Deck, Infinity Perfect 10" Cubby, JBL GTI 180.2 400wX1 rms, 6.5 Perfect components rear bar, front: Boston Acoustic Pro series 5.5 Infinity reference amp 111wX4 rms, Optima Yellow |
#3 |
Yes Man!
I Havent had any issues. I just scuffed with 100 grit before I sprayed my doors. A thicker coat will probably prevent any possible peeling. It only peeled off on mine where i missed spots with the sandpaper.
#4 |
Im also thinking about doing my roof. U pol is supposedly UV stable so I guess ill go for it. As for the sides i pressure washed the **** out of them and they held up fine.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
