Will installing a dropped pitman arm throw off my alignment? How bad? - Page 2 - JeepForum.com
post #16 of 17 Old 02-14-2011, 01:14 PM
Ben
Did you end up getting this on a rack?
I'm curious what the numbers were.
At low lift heights, it's not much of a change, cause the angle change isn't much. But the higher you go it creeps into the picture as a problem.
Ben is offline
post #17 of 17 Old 02-15-2011, 08:31 AM Thread Starter
LandRover
LandRover's Avatar
That was supposed to be yesterday, but I stripped a bolt working on my differential and couldn't drive it....
I will though, I called and the guy offered to check it for me. I will post up when I get it measured.
RHD '98 XJ
RE 3.5", Bushwaker Flat Flares,
OR-Fab bumpers, PowerTrax locker,
Sliders, Goodyear Duratrac 33's
LandRover is offline
dropped pitman arm? jake18274 XJ Cherokee Technical Forum 3 07-07-2009 06:41 PM
installing at trac bar and alignment? cardana24 XJ Cherokee Technical Forum 7 08-21-2007 01:22 PM
Dropped Pitman Arm dan240 XJ Cherokee Technical Forum 3 02-06-2006 06:34 PM
Pitman Arm Drop or Retarted Alignment guy? Mtxz453 XJ Cherokee Technical Forum 16 07-23-2005 06:18 PM
Dropped Pitman Arm? davidbullard XJ Cherokee Technical Forum 2 09-06-2002 06:31 AM
