Will i need new stearing stablizers if i put a three inch lift on my xj? - JeepForum.com
post #1 of 6 Old 07-02-2013, 05:51 AM Thread Starter
chalivingston
I've got a 99 Xj 4.0 with a stock suspension will I need new stabilizers if I lift it 3 inches?
chalivingston is offline
post #2 of 6 Old 07-02-2013, 06:29 AM
krawler510
Nope. Unless the factory one isn't working properly.
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline
post #3 of 6 Old 07-02-2013, 01:34 PM
CitadelXJ
Just remember if you go with bigger tires (33"+) or a lot of abusive trails you should either upgrade to an aftermarket steering stabilizer or be prepared to replace it every once in a while.
CitadelXJ is offline
post #4 of 6 Old 07-02-2013, 07:16 PM
ConnerXJ
You don't even really need a steering stabilizer. I'm running 3.5" of lift and 33's and my steering stabilizer snapped in two so I took it off and have been running fine without one for 3 months.
1998 XJ Cherokee classic / 3.5 inch tuff country suspension lift / 33in Hankook Dynapro MT's / Bushwacker fender flares / warrior (d-ringless) steel front bumper
Flexin' cars for the stars and bars. 'Merica.
ConnerXJ is offline
post #5 of 6 Old 07-02-2013, 07:22 PM
alexrule123
alexrule123's Avatar
I don't run any stabilizer and it drives fine.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #6 of 6 Old 07-02-2013, 11:57 PM
Timo_90xj
Timo_90xj's Avatar
There is only one steering stabilizer on an XJ, you certainly don't need two.
After lifting, what you need to do is remove the SS, do a proper front- end alignment, drive for a awile to make sure you don't get DW, only then install a new SS if you want to run one. If you plan to wheel your Jeep, I'd strongly consider swapping to stronger aftermarket stuff (or at least do a ZJ V8 tierod swap). Also make sure all steering and suspension components are in top notch condition. Loose/ worn parts in the front cause DW and other steering- related issues, which are not cured by an SS. You can run one if you want, it definitely won't hurt anything.
You don't necessarily even need a steering stabilizer if the steering is set up properly. It does help on certain aspects, but isn't necessary at all. I've been running two XJs on 35s with no SS, no DW, no other issues, and I run my ZJ on 32s with no SS - zero issues.
***Under construction***
Timo_90xj is online now
