Quantcast will this fit? Coolant temp sensor - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > will this fit? Coolant temp sensor
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 08-21-2009, 09:58 AM   #1
billabongopblue
is this the right coolant temperature sensor to fit my 96?
Coolant Temperature Sensor by BWD - Part 3461661 - Advance Auto Parts
I think i have been getting faulty readings on the temp gauge. This is the part to replace to fix that right? Thanks
billabongopblue is offline   Reply With Quote
Old 08-21-2009, 08:53 PM   #2
billabongopblue
anyone know?
Old 08-21-2009, 09:29 PM   #3
Holder350
1995 XJ Cherokee
That would not be the correct picture.....that looks like a GM unit.....let me do some digging and I will see if I can find some info for you.
95' XJ Country - Stock Skids - Limited Slip Rear Diff
Off Road Package - 4.0 HO - AX15 - NP231
Repeal Ohms Law!!!
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline   Reply With Quote
Old 08-21-2009, 09:46 PM   #4
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
AutoZone.com | | Coolant Temperature Sensor | COOLANT TEMP SENSOR The one you listed looks correct to me.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Old 08-21-2009, 09:58 PM   #5
Holder350
1995 XJ Cherokee
This is acctualy the one you need.
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Temperature-Switch-Sender-BWD_18970646-P_425_R|GRPSESWAMS_547248555___
Its located tward the rear of the head right next to the valve cover on the drivers side.....be VERY careful when installing the new one as they are easy to break. Also, I ended up grinding a socket down to make a thin walled on to use to put the new sensor in....a regular socket would not make it beside the valve cover.
The one you have found is the sensor that reads back to the computer, and tells the fan when to come on, the one above ONLY feeds the gauge.
Repeal Ohms Law!!!
Old 08-21-2009, 10:49 PM   #6
billabongopblue
Thank you so much, you have been a great help to me. Even in the past.
Old 08-22-2009, 08:51 AM   #7
ehall
1991 XJ Cherokee
NO THAT IS THE TEMP GAUGE SENDER FOR 1995 AND EARLIER MODELS
ehall is offline   Reply With Quote
Old 08-22-2009, 09:56 AM   #8
Holder350
1995 XJ Cherokee
Seems strange considering that the Borg Warner catalog shows the same sensor up till 1997 when the cluster changed to idiot lights.
Repeal Ohms Law!!!
Old 08-22-2009, 10:55 AM   #9
ehall
1991 XJ Cherokee
1995 and older used two completely different temperature probes. one is dedicated for the engine computer, and is located in the thermostat housing. the other is dedicated for the gauge/light, and is located at the back of the head.
1996 is the year that all of the cars switched to OBDII. As part of the implementation, Jeep eliminated the dedicated sender for the temperature gauge and began reusing the ECM temperature sensor. The 1996-1999 4.0 heads do not even have a hole for the temperature gauge/light sender
The OP has a 1996. Your link is for a 1995 temperature gauge.
Old 08-22-2009, 11:19 AM   #10
Holder350
1995 XJ Cherokee
I'm not going to waste my time arguing, and I have no personal experience on an OBD II Cherokee, besides a 00 model.
All I am saying is that the factory service catalog and the Borg Warner catalog both list the break year as 97 not 96
Repeal Ohms Law!!!
Old 08-22-2009, 11:22 AM   #11
cornbrizzle
1992 XJ Cherokee
OP"s link says it's for a 96 could be made during year change . He needs to look a his head near the fire wall on driver side and see if he has this sencor on his head.
Thats the way to be sure !!!
Brizzle
“Don’t Tread On Me”
www.highsprings.com
cornbrizzle is offline   Reply With Quote
Glock Forum
