#1 | |
will it clear?
i have either 3.5" lift or 4" not sure exactly... will i rub with 33's? will turning be affected? some say no, some say yes...
'95 ZJ.... new DD '98 XJ.... sold '98 XJ.... Sold...(biggest regret) '91 YJ.... Was mine,now dad's DD '94 YJ.... Sold... '95 ZJ.... Sold, '04 TJ.... Mom's DD.....'97 TJ.... Sold |
#2 |
Resident Audio Guru
33s will rub if you don't trim, yes.
-Matt White '94 YJ Sport Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar Project (s)Low - A build log. |
#3 | |
#4 |
it depends on the backspacing of your wheels. I have 32s with 3.75" backspacing that don't rub and tires that are about 29" that do rub
1997 Comanche - Started as a 1988 MJ 2wd 5 spd Now it has the front clip, motor, trans, axles and interior from a 1997 Cherokee. Long Arms and Locked on 32s. 1999 Cherokee DD |
#5 |
i have no clue on backspacing cuz i bought the rig with those on already... is there a way to meaure them to find out backspacing?
#6 |
Location: ....................... N41° 42.1' W72° 12.4'
Going by your sig. If those wheels are AR-767's your BS is 4"
Yer gonna rub. Get out the saw ![]() ....even with trim, rubbing the LCA's at full chock isn't out of the question. 3.75 BS would be desireable.
"Always do what you want, and say what you feel, because those who mind don't matter, and those who matter don't mind." - Dr. Suess |
#7 |
something most forget to mention is that if you go with a 33x10.5 you will have an easier time making them fit...... that is with stock, or close to stock, rim width and offset.
fuel in my veins, mountains on the brain...... Current-06 Unlimited. Past- 98 XJ, 95 YJ, some Fords. BUFFALO NY JEEPERS-http://www.wnyoffroad.org http://www.cardomain.com/id/yjjeepinmike Just your friendly neighborhood x-ford technician... |
#8 | |
idk 10.5 dont look right to me.. i have 12.5 right now and like them being wide
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
