Will a 96 Comanchee Hood fit my 89XJ? - JeepForum.com
post #1 of 7 Old 12-04-2009, 08:21 AM Thread Starter
CharlieMopps
1989 XJ Cherokee
I found one for possibly cheap... and mines all banged up. But its 2hrs away. Does anyone know if it will fit?
CharlieMopps is offline
post #2 of 7 Old 12-04-2009, 08:25 AM
maxgordon7
hmm I have a 96 green hood in waukesha outside milwaukee. An hour away. They made comanchee in 96?
maxgordon7 is offline
post #3 of 7 Old 12-04-2009, 08:28 AM
RedZeppelinXJ
Comanches were only made from '86-92 but i believe that all hoods from XJ's and MJ's from '84-01 are interchangeable
'99 XJ Sport - The Green Lantern (sold) 4.0/AX-15/NP231/HP30/C8.25, 3" RC lift, 30's
'96 XJ Sport - The Red Zeppelin (DD) 4.0/AX-15/NP231/HP30/C8.25, 2" BB, IRO Front Hooks, Hella Black Magics
'91 XJ Briarwood - The Spruce Moose (Parting Out)
'79 J10 - Spartacus (Parting Out)
RedZeppelinXJ is offline
post #4 of 7 Old 12-04-2009, 08:34 AM Thread Starter
CharlieMopps
1989 XJ Cherokee
doh, your right 86
post #5 of 7 Old 12-04-2009, 08:35 AM Thread Starter
CharlieMopps
1989 XJ Cherokee
You got axles to? I need a front with 4:10s in it
post #6 of 7 Old 12-04-2009, 09:09 AM
maxgordon7
3:55 gone already
post #7 of 7 Old 12-04-2009, 11:13 AM
RedZeppelinXJ
cherokees with the 2.5L I4 and 2.8L V6 came with factory 4.10's i believe and are bolt in.
Also 2.5L I4 YJ's came with 4.10 gears, they are set up for leaf springs but because they used the High Pinion D30 the gears, carrier, etc should go right into your existing front end. You cant use TJ gears tho because they use the Low Pinion D30.
1988 Jeep Comanchee Will not rev up batchje MJ Comanche Technical Forum 7 08-28-2009 06:37 PM
1992 Comanchee chilidog75040 MJ Comanche Technical Forum 1 08-15-2007 02:08 PM
96 comanchee wont start, please help!!!! strykere4 XJ Cherokee Technical Forum 5 07-23-2006 10:37 AM
88 Comanchee 4WD Frnt Whl Bearing bhljeep MJ Comanche Technical Forum 3 07-20-2005 09:35 PM
Electric Fan - Again (88 Comanchee) bhljeep MJ Comanche Technical Forum 4 05-27-2005 07:10 PM
