Quantcast will 87 engine header and oil pan work on a 95? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > will 87 engine header and oil pan work on a 95?
Old 02-15-2008, 01:38 PM   #1
TheCherokeeKidd
rock hoppin & mud sloppin
TheCherokeeKidd's Avatar
got a parts jeep that is a 1987 4.0l and i need a header (mine is cracked) and the oil pan (mine is bent and won't seal) for my 95....will these items swap over? i know the 87 is renix, but is the header different? anyone have experience with this? thanks....
1997 Wrangler, 2.5l 5 spd 4.88 winch...etc
2011 Kia optima SX turbo (wife's car) 274hp but 34mpg!
2010 Kawasaki Vulcan 900 custom
TheCherokeeKidd is offline   Reply With Quote
Old 02-16-2008, 12:42 AM   #2
CanadianJeep86
the exhaust manifold will bolt up but I'm pretty sure they used 2 different designs from 87 to 95. Just look under the hood and check it out.
The oil pan should be the exact same because the bottom end of the motor never really changed at all.
1984 Suzuki SJ410, 1.3L 5speed, soft top, spoa, shackles, bodylift, 6 offroad lights.
1988 Dakota, 318, 5 speed, 4.10's, rollbar, lowered 3".
1986 2dr XJ, 2.8, 5 speed, Bushbar,
1989 XJ, 4.0, AW4, NP231, D44, 3.73's, *Stolen*
1987 MJ Sportruck, 2.5, AX5, Rollbar, *Jeep Heaven*
1986 MJ, 2.5, T-5, bushbar, Longbox, *Jeep Heaven*
CanadianJeep86 is offline   Reply With Quote
Old 02-16-2008, 07:06 AM   #3
badassls1z
I'm thinking the header is different, it might work, but if it isnt already cracked it probably won't be long before it is. IMO, if you are gonna take the time to replace it, just put a new one on it. The oil pan should work though.
'06 Wrangler X, 4.0 Auto, 31" Kumho MT's on Black Cragar v-5's
'92 White XJ Laredo, 3" Lift, 33's SOLD
badassls1z is offline   Reply With Quote
Glock Forum
