Wierd Speaker Issue - JeepForum.com
post #1 of 8 Old 09-13-2011, 03:42 PM Thread Starter
dmlacrosse42
Wierd Speaker Issue
OK, so i have a 2000 jeep cherokee limited, and ive had an issue with the drivers side front speaker a few months after i bought it. I did some research and found that this isnt an uncommon issue. It usually resolved itself just by opening and closing the door a few times, and it would be back in working order. This week, it cut out again, and the usual trick of opening and closing the driver door didnt fix it. I looked at the wires, and from what ive heard, the green wire is the ground wire which most likely frayed. I got my fingers on it and felt inward towards the head unit and it broke right there. I grabbed some wire i had laying around, and just temporarily grounded it to a bolt on the inside of the door where the hinge is. Now heres my issue......the speaker is half as loud as the rest, AND when i turn the power on in the car, only the two rear speakers work. I have to open my drivers door and slam it, and then both front speakers work. The front right plays fine, but the front left doesn't. Id like to fix this rather than paying a nice penny. I know for a fact it isn't the speaker because i just replaced it. Any tips?
dmlacrosse42 is offline
post #2 of 8 Old 09-13-2011, 04:17 PM
meatlord
Maximum Disaster
meatlord's Avatar
I hope you didn't ground a speaker wire to the body.......... that is not how the system works. All neg speaker wires MUST return to the head unit itself only. Run a new pair of wires to the speaker if you want it to work, that flex point is bad on wires to
05 Rubicon "Big Stupid" / 99 XJ on 31s "Nurple" SOLD. / 07 WK Limited CRD GDE Hot Tuned DPF delete. / 00 TJ "One Shot Wonder"/ 12 Altima 3.5 SR CVT / 00 Suzuki DR650.
meatlord is online now
post #3 of 8 Old 09-13-2011, 04:19 PM
JeepFreak1982
Open the door and remove the rubber boot from the door and body. Slide it into the body or door and fix the broken wires. Im sure you will find more than one. The XJ door boot wiring is terrible.
JeepFreak1982 is offline
post #4 of 8 Old 09-13-2011, 04:32 PM
NJXJ91
I just ran completely new wires from the deck to the head unit. A little time consuming but now I dont have to worry about any of that
NJXJ91 is offline
post #5 of 8 Old 09-13-2011, 04:36 PM Thread Starter
dmlacrosse42
ok, now its a stock head unit. how do i get behind it so i can run a new wire to the door
post #6 of 8 Old 09-13-2011, 04:37 PM
JeepFreak1982
The speaker wires are not the only wires that crack. They all do and every one of em is a problem. Last XJ i fixed had 9 broken wires and 4 more that were broken 1/2 way through. That was just the drivers door.
post #7 of 8 Old 09-13-2011, 07:19 PM
cake
when i installed speakers and a head unit i found quite a bit of broken wires. the good news is that I now have working front speakers. the bad news is now i know how much of a pain in the *** its going to be to fix the rear window, and side view mirror.
cake is offline
post #8 of 8 Old 09-13-2011, 07:23 PM
JeepFreak1982
The Jeep i mentioned above came in with all sorts of problems. Keyless problems, power lock problems, power window problems, all caused by the broken wires in the drivers door boot. If you are having power window problems or power mirror problems you may very well have the same issues.
cherokee , speakers , wiring , xj
Wierd AC issue viper21700 XJ Cherokee Technical Forum 2 07-27-2011 05:57 PM
Wierd issue after start up... looking for more ideas mudjive XJ Cherokee Technical Forum 0 05-23-2011 09:24 AM
Wierd Fuel issue any ideas? gradysjeep XJ Cherokee Technical Forum 2 06-05-2007 11:10 PM
Wierd Starter Issue Ludoc XJ Cherokee Technical Forum 6 06-16-2005 07:35 PM
Wierd Brake Issue xjrrrdx XJ Cherokee Technical Forum 4 05-03-2005 03:48 PM
