Wierd oil pressure problem - Drops to 0 at idle! - JeepForum.com
post #1 of 8 Old 11-19-2008, 03:10 PM Thread Starter
Whtfairladyz
Ok guys, I did some searching. And I have yet to find any kind of answer to point me in the right direction.
My 2000 XJ is having, what I think, is oil pump problems.
Under normal driving conditions, about 99% of the time, my oil pressure is PERFECT. No issues what so ever. Runs about 60 under load and roughly around 25 to 30 cruising... 10 to 15 at idle.
I noticed the other morning going to work while I was sitting in traffic that all of a sudden my CHECK GAUGES light came on and I had 0 oil pressure. I paniced and shut the motor down. I got out and checked everything over and visually, things looked OK.
I started the Jeep back up, perfect oil pressure. After some more head scratching I drove on to work. A few days later, it did it again!
The condition is this....while at idle for more than a minute. My engine's oil pressure drops to 0! However, works perfect at all other points in time. And when the engine drops to 0, you can slightly rev the engine to ~1000rpm and viola! oil pressure comes back. Something else that is wierd...it does not do it all the time. It is sporadic, seeming to do it only when the engine temp is at normal operating temp.
Any advise would be appreciated!
Whtfairladyz is offline
post #2 of 8 Old 11-19-2008, 03:16 PM
JFM626
JFM626's Avatar
More then likely the sending unit, but if you need to be sure hook up a manual gauge
JFM626 is offline
post #3 of 8 Old 11-19-2008, 03:36 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
The vast percentage of strange oil pressure readings are caused by a faulty oil pressure sending unit as already mentioned. If your oil pressure truly was zero, you'd probably be hearing some engine noises. Some guys just replace them as they're cheap (I recommend buying from Jeep for best gauge mating accuracy) or if you're ambitious, get a hold of a mechanical gauge and temporarily hook it up where the oil pressure sending unit is and compare readings to what you're seeing.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #4 of 8 Old 11-19-2008, 06:53 PM
wheelin79cj
Yep, Just freaked out today when the wife called and said her oil pressure was at 0. Hooked up the manual gauge and it was perfectly normal. In the process (actually when I first took it out) I noticed that it had a bunch of oil in the electrical plug side of it. Good news to me, I almost had to buy my neighbors Cherokee that has a new bored out 4.0 and a lift already....lol
-Aaron
wheelin79cj is offline
post #5 of 8 Old 11-24-2008, 01:28 PM
ArmyFireFighter
anyone know where to get one of these Manual Gauges?
ArmyFireFighter is offline
post #6 of 8 Old 11-24-2008, 01:42 PM
440_Magnum
Agree on the sending unit, especially if its OK after a shutdown and restart. They leak oil past the internal diaphragm, and when enough oil builds up on the backside, they read 0 pressure. Turn off, oil forces its way back out and they're good again for a while. Pretty common failure on any vehicle with an electric oil pressure gauge.
That said, NEVER roll the dice with oil pressure. If it really does go to zero, your engine has about a minute (or less) to live without damage if you're driving. A little longer at idle/no load.
440_Magnum is offline
post #7 of 8 Old 11-24-2008, 01:47 PM
440_Magnum
Most good auto parts stores have them.
Here are a few low-end ones from Summit:
http://store.summitracing.com/partde...5&autoview=sku
Believe it or not, I've had a few of those cheap Sunpros that have lasted for years. They're not bad at all, considering the low price. Even Pep Boys carries them.
And besides, the cheapest mechanical gauge is more trustworthy (in my opinion anyway) than a much more expensive electrical oil pressure gauge.
post #8 of 8 Old 11-24-2008, 02:26 PM
ArmyFireFighter
me and my buddy just gerry riged one from the hardware store. Turns out I will need a oil pump. starting first thing tomorrow,
Wish us luck.
Engine temp drops at idle.. 98GooseXJ14 XJ Cherokee Technical Forum 3 12-06-2009 10:38 PM
Oil Pressure Drops to 0PSI When It's Warm xjarchaeologist XJ Cherokee Technical Forum 10 04-22-2009 09:44 PM
Turn steering wheel & idle drops tombob XJ Cherokee Technical Forum 2 08-09-2008 08:28 PM
Oil pressure problem at anything over idle dohp XJ Cherokee Technical Forum 8 01-09-2008 01:21 PM
oil pressure drops to 10?????? arieljeep XJ Cherokee Technical Forum 10 12-09-2004 08:10 PM
