Why won't my Jeep start after new starter? (starter works, no spark??) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Why won't my Jeep start after new starter? (starter works, no spark??)
Ruffstuff 10 year saleRegear now with Gear Packages from JeepHut.comSmittybilt M1 Fender Flares + FREE Machete
Unread 04-24-2008, 10:12 AM   #1
DuaneJ
1994 XJ Cherokee
Hello
I'm a brand new Jeep owner, just picked up a 1992 Cherokee the other day.
It required a few basic things (battery, starter, tires, etc.).
I just put the new starter in this morning. With the new battery and starter, the motor spins really well. However, it won't fire off. No problems with starting before the new battery and starter.
What in the world could I have screwed up by just replacing the starter? I can't possibly see leaving the battery disconnected overnight causing a problem ?!?
It's not fuel, I pulled the line off and there's plenty of fuel incoming.
Any ideas or things I should try?
Thanks in advance for lending a hand to a Jeep newb.
DuaneJ is offline   Reply With Quote Quick reply to this message
Unread 04-24-2008, 11:02 AM   #2
DuaneJ
1994 XJ Cherokee
After doing some research, it seems there's something called a crank position sensor that can cause this phenomenon?
Could I have jacked that up by disconnecting the battery?
Unread 04-24-2008, 01:38 PM   #3
DuaneJ
1994 XJ Cherokee
Yet another update...
I have spark. I've got to find a fuel pressure gauge to check pressure.
Is it just coincidence that this started after changing my starter? I'm still thinking I must have done something ...
Anybody take a stab at this ??
Unread 04-24-2008, 10:21 PM   #4
XJ4oh
1997 XJ Cherokee
Leave the ground wire(s) disconnected accidentally? Possibly shorted something out?
'97 XJ... 4.0 4x4 AW4. 2" budget boost w/t-case drop.
31x10.5 Cooper Discoverer ST's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
'04 WJ - Columbia Edition - 4.7HO 2WD
XJ4oh is offline   Reply With Quote Quick reply to this message
Unread 01-05-2010, 08:59 PM   #5
jeepitup1
Oxygen sensor might be bad?
jeepitup1 is offline   Reply With Quote Quick reply to this message
Unread 01-05-2010, 09:01 PM   #6
631XJ
oxygen sensor and coolent sensor go hand and hand you get em checked out ... mayb nuetral saftey switch? just got all of these sensors and switches replaced in my 97 jeep starts and runs perfect now
Long Island
631XJ is offline   Reply With Quote Quick reply to this message
Unread 01-05-2010, 09:09 PM   #7
robdoggydog1
1970 CJ5
have you tried to start it in nuetral? also check if any wires on the starter moved while you were tightening they may be grounding out or shorting.touching eachother .
robdoggydog1 is offline   Reply With Quote Quick reply to this message
Unread 02-11-2012, 04:02 PM   #8
Mdeez415
1988 XJ Cherokee
I am having the same problem, I started a similar thread... check it out http://www.jeepforum.com/forum/f11/helllp-1323954/
Mdeez415 is offline   Reply With Quote Quick reply to this message
Unread 02-11-2012, 06:24 PM   #9
tjwalker
It's the crank sensor!
tjwalker's Avatar
Is your spark a strong, blue snapping spark? Yellow/orange/white indicates a weak spark which may not be strong enough to start the engine.
If spark checks out (and only if), then try a bit of starting fluid into the intake or a splash of gas. If the engine starts and runs momentarily with this technique, you have identified a FUEL DELIVERY problem.
The above tests are really necessary to help isolate the issue.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is online now   Reply With Quote Quick reply to this message
Unread 02-11-2012, 06:34 PM   #10
DezertXj88
1990 XJ Cherokee
Did said jeep start before the parts were replaced?
All grounds checked, cleaned and tightened?
My jeep would crank for days, just wouldn't turn over. Mine is a 88/89 and it turns out I shorted out my ecu somehow. My point is, it can 1 of a million things. Time to start the process of elimination. I'd follow advice in steps, make sure you do it right..if it doesn't work come back for more!
But as said. First did the jeep start before this? Are all grounds checked, cleaned and tightened?
DezertXj88 is offline   Reply With Quote Quick reply to this message
Unread 02-13-2012, 02:14 PM   #11
Mdeez415
1988 XJ Cherokee
Could it be cps ( crankshaft position sensor )?
Unread 02-13-2012, 03:22 PM   #12
Azzy
It is possible, they get all weird when going. When mine acted up, it would start on starting fluid, but never by itself, when all else checked out good.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline   Reply With Quote Quick reply to this message
Unread 02-13-2012, 03:45 PM   #13
Mdeez415
1988 XJ Cherokee
I think mine is goin at the moment. It's my daily driver. Sometimes it starts great , sometimes it just cranks with no fire. Is it hard to change and how am I sure this is the problem before buying hella new parts?
