Quantcast Why does my liftgate rattle - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Why does my liftgate rattle
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.com
Old 02-08-2010, 02:43 PM   #1
themow
this is a new occurrence. Seems like it is not latching all the way. I took apart the latch and oiled it but dont see any adjustments on it. What am i missing?
98 XJ 4.0 AX15
03 Wj overland sold what junk!!!
06 wk 3.7
themow is offline   Reply With Quote
Old 02-08-2010, 02:58 PM   #2
Apostle
the latch clicks twice on 97+ if its only clicking once, its broke and will rattle. can allways get some rubber bump stops and mount those, so when the hatch closes, the bump stops push on it
2011 JK Wrangler - Sahara Tan SOLD
2012 JKU - White
Apostle is offline   Reply With Quote
Old 02-08-2010, 03:07 PM   #3
jdest001
On my '98 there were already bump stops on the body that the liftgate came in contact with when it closed. They're just rubber and mine were really cracked and my gate was rattling, i replaced them and all is well now. They're also adjustable, if you pull off the rubber part there is a torx screw and you can turn that to adjust how tightly it fits against the door. Hope this helps.
jdest001 is offline   Reply With Quote
Old 02-09-2010, 11:37 AM   #4
themow
well it is clicking twice...the rubber stops are there but arent cracked....im so sick of this rattle.....should the gate have pressure pushing it outward when closed????? i would think pressure pulling it in...is there no way to adjust the latch???
98 XJ 4.0 AX15
06 wk 3.7
Old 02-09-2010, 11:42 AM   #5
Lilxj95
1995 XJ Cherokee
mine was rattleing and it was as simple as my lisence plate being loose. maybe you've got the same problem...
Lilxj95 is offline   Reply With Quote
Old 02-09-2010, 11:48 AM   #6
themow
checked that...negative
98 XJ 4.0 AX15
06 wk 3.7
Old 02-09-2010, 12:05 PM   #7
Apostle
you cant adjust the latch, but you can adjust the hatch. the top mounting plates, sometimes there are shims in them. search on here, sure someone had the same problem
2012 JKU - White
Old 02-09-2010, 01:34 PM   #8
dcorn
Did you search?
The loop part of the latch on the bottom of the hatch opening can be adjusted. It looks like there are studs that can't be adjusted. The nuts to adjust it are on the bottom. Look down between the metal bumper and the hatch weather seal and you'll see them. You can reach them with a deep socket and a 10" extension. If your hatch is rattling, the loop needs to be moved just a tad toward the front of the Jeep. Loosen both nuts just a bit and tap the loop to move it slightly. Tighten them up and close the hatch to see if it helped. If you move the loop too far forward, the hatch won't latch shut.
FOR SALE 1998 Cherokee Classic - White
5" lift - 35" tires - locked/geared/shafted/armored
2012 Subaru WRX Limited
dcorn is offline   Reply With Quote
Old 02-09-2010, 01:37 PM   #9
EddieXJ
Lets go Pens
EddieXJ's Avatar
1997 XJ Cherokee
Slam it really hard
EddieXJ is offline   Reply With Quote
Old 02-09-2010, 02:00 PM   #10
Wearingthin
*something clever*
Wearingthin's Avatar
Are you sure its the liftgate? Does the rattle stop when you push on it?
Wearingthin is offline   Reply With Quote
Old 02-09-2010, 02:20 PM   #11
keepishop
keepishop's Avatar
1989 XJ Cherokee
The bumpstops push the hatch in the open direction. That counters gravity which is pushing it closed. Takes all of the wiggle room away. Wiggle = rattle.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap, bronco 2 carrier, rad fan switch
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline   Reply With Quote
Old 02-09-2010, 04:04 PM   #12
Fury3
Fury3's Avatar
My tailgate rattles like heck too. Makes me insane. Did a search and found these bumpers, they're located on the body side of hatch and mine were shot to hell so I ordered a set.
Found them here: Jeep XJ, Jeep Cherokee, Jeep Comanche and Jeep Wagoneer Parts: Tailgate and Related Parts
Scroll down, they're third from the bottom.
...boldly go
2K Cherokee w/4" lift, armored, shafts, rear Aussie, AA's Sye, Warn's Hub Conversion.
Fury3 is offline   Reply With Quote
Old 02-09-2010, 05:21 PM   #13
themow
Originally Posted by dcorn View Post
Did you search?
This sounds like the problem. I will look into it.
98 XJ 4.0 AX15
06 wk 3.7
Old 02-09-2010, 05:25 PM   #14
themow
my rubber bumpers dont look bad at all....infact they look new
98 XJ 4.0 AX15
06 wk 3.7
Old 02-09-2010, 05:37 PM   #15
Lifesgoodhere
1989 XJ Cherokee
take a few washers under the bump stops....cured mine rattle.
1949 Jeep Truck; just needs paint
*My YouTube videos Subscribe!
*My Jeep Build Thread >>Epic project
Certified Jeep Expert, and Volvo Mechanic
Lifesgoodhere is offline   Reply With Quote
Glock Forum
