#1 | |
Who hates Rust?
Have a question if anyone has used a product that slows down rusting. I found this booklet at my local 4X4 store about a product called Counter Act. It is a Electostatic Corrosion Control device. They have a web site www.counteractrust.com
I talked to a co-worker and he said that the product or IDea is not new and that it works. Just want to see if any one uses it and what their thoughts are on it. Why I want this is I live where it rains alot and my Jeep is outside. ![]()
The meaning to life is to live, So Go Live....Offroad :o) [COLOR=red]******************************************[/COLOR] [B][U]1998 Cherokee, 2 Door, Black.[/U] [/B] 4.0 L Power Plant, NP231 Transfer Case 32" BFG All Terrain Tires on 15"x7" "Grizzy" Jeep wheels Helix TB Spacer with K&N Replacement filter. C4x4 Rear Bumper/Tire Carrier with hitch and towhooks :) DPG Rock Attack XJ Gas Tank Skid Plates RE 4.5" lift - With 1" 5/8 Spacer up front, and 1" Spacer and 3/8 shim in back. So over 6" of lift. |
#2 | |
Chris 1998 Cherokee 4x4 BFGoodrich A/T KO tires Flowmaster 40 Series ...everything else pretty much stock! |
#3 |
Little Red Menace
Where is the rust you're trying to stop?
93 Sport Beer is proof that God loves us and wants us to be happy............Ben Franklin Specs in Profile. http://www.cardomain.com/ride/325707/1 http://www.cardomain.com/ride/2406854/1 |
#4 | |
Dont realy have rust issues yet. The product prevents rust. It uses Electrostatic to prevent rust from forming. you should read up on it. But thx for asking. just wanted to see if anyone has ever used such a device.
#5 |
in college chemistry books they tell how those things work, some can work by putting a "sacrificial piece of metal on it somewhere and that piece will rust before the rest of it, can't remember exactly why it works that way
might be worth trying, in order to keep something like this from happening http://home.earthlink.net/~scs748_2/qpanel1.JPG |
#6 | |
EEEEEKKK!!!! OMG Thats scary sh@! Hope thats not yours, and if it is please tell me you fixed it. ![]()
#7 | |
#8 |
Sacrificial Anodes
Those of use who have ever owned boats that are used in salt water are quite accustomed to the principle of a sacfricial anode.
The idea is that when two different metals are in contact with each other then a reaction occurs that causes rust. Usually there is moisture and/or salt in the equation. A sacrificial anode is a piece of metal (on outboards is is generally a small fin used for directional stability) that is made of an alloy that is weaker than the surrounding metals, this causes it to corrode instead of the more expensive parts. There you are. Hope this simple explanation helps. ![]()
[B]Black '91 Limited[/B] 4.0L HO, Stock Dana 30/35 Diffs, NP242 / SelecTrac 3" Black Diamond Lift, Home Brew TC Drop, 31x10.5's Aussie Locker in the rear, Teraflex rear disk brake conversion. |
#9 |
Im sure you guys have heard of Durabak??? It is a non slip lining , or bedliner , like rhino lining but better. Check out this site, www.nonslipcoating.com . There is an XJ covered with this stuff. You cant scratch it, its impervious to salt, rust, and UV , just about everything. If done correctly can look very good, and you would never have to wash or wax it. And if you cover your chassis in it, you would never have to worry about salt or rust on that again. Plus it comes in a smooth or texture finish. And in many colors. Damn sounds like Im a sales rep for these people, I swear I am not. Im pondering getting some for undernieth my XJ, and maybe more. Just sounds like a great product.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
