Who has removed the head on an 01 - JeepForum.com
post #1 of 6 Old 02-11-2011, 02:29 PM Thread Starter
twomanyjeeps
Hi all,
I'm replacing the head on my 01 after the original cracked and I just had a few questions after reading the manual:
1.) Felpro gasket from Autozone says not to put sealer on the gasket, but the manual (Haynes) instructs to do so...who do I believe (my guess is Felpro, but just making sure.)
2.) Did you replace head bolts or just clean the old ones up and re-use them.
Thanks in advance for any help
twomanyjeeps is offline
post #2 of 6 Old 02-11-2011, 03:56 PM
AZ Jeff
2014 JK Wrangler
Follow the recommendations of the gasket manufacturer, and NOT the Haynes manual.
Head bolts are of the "torque to yield" type construction. As such, they are intended to be reused ONCE. If they are reused, the recommended practice is to pad dab each bolt head so that the next guy working on the engine will know if the bolts have been reused. Now the trick is....will this always be done.
Owing to that, you may or may not be able to trust whether the head bolts were ever reused before. Proceed accordingly.....
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 6 Old 02-11-2011, 04:20 PM Thread Starter
twomanyjeeps
Thanks Jeff,
I've had the vehicle since 40k miles so I'm pretty sure the head was never service before that. Thanks again for the heads up.
post #4 of 6 Old 02-11-2011, 04:39 PM
Back_In_Black
just did mine last week! its a pain, but I used no sealer, and bought the felpro complete set from Auto zone. what company did you buy a head from? make sure you take it to the machine shop, and if you get the complete gasket sear it will come will valve stems.
Back_In_Black is offline
post #5 of 6 Old 02-14-2011, 10:30 AM Thread Starter
twomanyjeeps
The head came from a local machine shop, they took a new head with a different casting and assembled the head with my old valves after a valve job and all the other stuff. The head is back on and I didn't use sealer on the Felpro gasket. I didn't buy new bolts either. I just chased the threads in the block and on on the bolts and looked for any signs of necking on the bolts. I was just getting the manifolds torqued up when I got kicked out of the garage so i haven't run the vehicle yet. Thanks for the input though guys.
post #6 of 6 Old 02-14-2011, 01:52 PM
Back_In_Black
good luck!
0630 head with coolant temp sensor port at back of head? crmaverick89 XJ Cherokee Technical Forum 6 02-19-2012 06:33 PM
Ordering New Bolts - Hex Head w/ Washer as good as Hex Flange Head? 00XJ49 XJ Cherokee Technical Forum 1 05-26-2010 02:07 PM
Pics of the removed head that is cracked (0331) JeepXJ2001 XJ Cherokee Technical Forum 26 05-17-2009 11:07 AM
0331 head swap 7120 removing the head from 92 to 2000 what all parts are needed amazingman XJ Cherokee Technical Forum 3 05-14-2009 12:57 PM
Blown Head Gasket or Cracked Head (Head is off w/ pic) Spike101188 XJ Cherokee Technical Forum 6 06-02-2008 09:13 AM
