-   -   White Smoke from Jeep Cherokee 2001??? (http://www.jeepforum.com/forum/f11/white-smoke-jeep-cherokee-2001-a-1520698/)
Adrian17 05-08-2013 07:04 PM
I dont know much about engines but today i let my mom drive my car for work. I just changed the oil a week ago. I did everything right im pretty sure since no leaks or anything occurred. Now today my mom was coming home from work and filled up the tank all the way which i never filled it up full completely and started driving home and said it started smelling like something was burning and weird as soon as she turned down our street which i thought it wasn't my jeep until 5 mins later i get in and it starts up. Took longer then usual to start it.Then as soon as i started driving i new the steering was weird and noticed it really wanted to turn left on its own i put the steering wheel straight and just wanted to make a left on its own. Also i noticed when i was going faster it felt like the engine wasn't perform as it should as soon as i let go of the gas pedal the mph dropped as if i was holding the brakes so i was driving and smelled the smoke that smelled funky and then stopped because i just saw white smoke coming out of the hood. No leaks nothing I don't know what the problem could be since after an hour started it up and everything went back to normal steering was great as if nothing was wrong. Gas pedal and the engine felt as if nothing was wrong and it was nice and cool with no problems? so can someone have an idea of what caused this to happen and make the engine overheat? As of now it seems to be fine but i wana get whatever caused the smoke and overheating replaced for a long trip that i want to take my jeep with.
Adrian17 05-08-2013 07:23 PM
bump
CJ7-Tim 05-08-2013 07:28 PM
What was the source of the smoke ?
Did it smell like hot coolant, or like burnt brakes ?
sluff28 05-08-2013 07:34 PM
5 Attachment(s)
First I would check my power steering pump to see if I had fluid if the power steering pump was fine I would take my serpentine belt off and check all of my pullys check your oil and just to be on the safe side transmission fluid. Check brakes and fluid These are the places that I would start I'm no expert hopefully someone with more experience than myself will chime in.
Adrian17 05-08-2013 07:34 PM
i dont even know how to describe the smell just smelled like something was burning it was coming from the engine once i opened up the hood where the oil cap is. I opened the cap and i could see white smoke coming from there but the whole engine was hot when i touched the top of it.
cjfan13 05-08-2013 07:46 PM
I would jack up front end and spin the tires to see if they spin free. Running hot could be low coolant or something
CJ7-Tim 05-08-2013 08:16 PM
Originally Posted by Adrian17 (Post 15408099)
.... it was coming from the engine once i opened up the hood where the oil cap is. I opened the cap and i could see white smoke coming from there .....
You need to stop driving until you diagnose the problem. I suggest you Google cracked 0331 head , and then have your Jeep towed to a trusted independent repair shop.
Paradise XJ 05-08-2013 08:22 PM
I think your mom screwed things up by filling the tank all the way
Kidding!
White smoke could be:
  1. Power steering fluid leaking on to hot engine parts (since you mentioned weird steering). That would explain a weird smell. Power steering fluid will catch fire if it gets too hot leaking on your exhaust.
  2. Transmission fluid leaking on hot engine parts. Transmission fluid will also catch fire.
  3. Coolant leaking on hot engine parts. Coolant will not catch fire.
  4. A seized or sticking brake caliper (since you mentioned it pulling to the left). Hot brakes WILL catch fire.
  5. Worst case: Coolant in oil via a cracked head or blown head gasket (since you have an 0331 head).
My next move would be figuring out how to put a complete sentence together so people will understand you and you'll be able to graduate high school and get a job (or don't they worry about punctuation anymore?)
sluff28 05-08-2013 08:22 PM
5 Attachment(s)
CJ7-tim has it right on the nose if there was a lot of white smoke do what he said. (if it is a cracked head) and you keep driving it a remanufactured engine stats at 3k installed and goes up from there.
Adrian17 05-08-2013 08:26 PM
i took it for a drive around the neighborhood which you may think is stupid but the problem is gone which is good but not good since i dont know what caused it and itll probably happen again.
Adrian17 05-09-2013 04:28 PM
i found out what the problem is it was actually my brakes on the left driver side that caused the smoke. the brakes stay attached without even being pressed on and caused it to start smoking and even could of started a fire which good thing it didnt. Without even pressing the brakes it caused only the left driver side while all the other brakes were fine. Thats why it was turning left for a random reason and smelled like crap because of the brakes and it smelled exactly like the smell in the car. Thanks for trying to help guys but problem solved and hopefully this is helpfull for someone else that has the same problem.
CJ7-Tim 05-09-2013 05:57 PM
Pulling to one side and lugging the engine pointed to brakes, but you said the smoke came from the motor :confused:
Paradise XJ 05-09-2013 09:12 PM
Originally Posted by Adrian17 (Post 15407941)
I dont know much about engines ...i was driving and smelled the smoke that smelled funky .
coming from the engine...the whole engine was hot when i touched the top of it.
Engines are usually all hot when you touch them.
[*]A seized or sticking brake caliper (since you mentioned it pulling to the left). Hot brakes WILL catch fire.
I still go with ^^ this advice...it may make you mad that I point it out...but it's IMPORTANT!! You can thank me when you're 30 and are trying to get your kids to do their homework!!
I don't think he really knew exactly where the smoke was coming from...just "from under the hood".
AirManPruett 07-21-2013 02:33 AM
i had the same thing happen to me yesterday. but the smoke was coming from the driver side front wheel on my 90 yj. i think it might be the calibers on it most likely with pistons sticking
The time now is 04:46 AM.
