Where is my temperature guage sending unit? ('98 XJ) - JeepForum.com
post #1 of 12 Old 12-14-2010, 01:09 PM Thread Starter
LandRover
LandRover's Avatar
Is it on the thermostat housing?
Either my Jeep is running REEEEEEAAALLLY cold or the sending unit failed.
It's a '98, 4.0. I'm seeing random plugs everywhere...which one is the right one, or are there multiples?
RHD '98 XJ
RE 3.5", Bushwaker Flat Flares,
OR-Fab bumpers, PowerTrax locker,
Sliders, Goodyear Duratrac 33's
LandRover is offline
post #2 of 12 Old 12-14-2010, 01:11 PM
cornbrizzle
1992 XJ Cherokee
It's the censor on the thermostat housing.
Brizzle
“Don’t Tread On Me”
www.highsprings.com
cornbrizzle is offline
post #3 of 12 Old 12-14-2010, 01:13 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Make sure the sender wire connection is clean and the wire is not damaged.
CJ7-Tim is offline
post #4 of 12 Old 12-14-2010, 01:13 PM Thread Starter
LandRover
LandRover's Avatar
Thanks.
RHD '98 XJ
post #5 of 12 Old 12-14-2010, 01:15 PM Thread Starter
LandRover
LandRover's Avatar
I just bought it and I think the PO had the engine compartment steam-cleaned... it's super clean, but I'm wondering if this could have messed with a close-to-messed up wiring situation. I have a spare Jeep out back, I'll swap out the plug and see
RHD '98 XJ
post #6 of 12 Old 12-14-2010, 02:12 PM
dukie564
dukie564's Avatar
1995 XJ Cherokee
incorrect to all the previous posts. The sensor Tim indicated is indeed the CTS, but it only is a switch that tells the thermostat when to open. The Coolant Temperature Sending Unit for the gauges is at the rear of the head on the drivers side of the valve cover on a late model XJ.
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #7 of 12 Old 12-14-2010, 02:40 PM Thread Starter
LandRover
LandRover's Avatar
^^ true for 97-01 XJ's?
RHD '98 XJ
post #8 of 12 Old 12-14-2010, 02:51 PM
dukie564
dukie564's Avatar
1995 XJ Cherokee
correct...true for 91-01 XJs
dukie564 is offline
post #9 of 12 Old 12-14-2010, 02:54 PM
Carves
ummm .... No.
Coolant temp sensor is as depicted in the pic posted by CJ7-Tim
Carves is offline
post #10 of 12 Old 12-14-2010, 02:56 PM
CJ7-Tim
CJ7-Tim's Avatar
OBD-II, 1997-2001 only have 1 sensor.
CJ7-Tim is offline
post #11 of 12 Old 12-14-2010, 02:59 PM Thread Starter
LandRover
LandRover's Avatar
Ooh this is getting good. Is the rear one a guage feed and the front one a thermostat switch, or what? Is the rear one just for pre-97's? The Jeep isn't here so I can't look for the rear one.
Edit, posting at the same time as Tim. I've heard of having to plug that rear hole when doing a head swap on a newer one...
RHD '98 XJ
post #12 of 12 Old 12-14-2010, 03:12 PM
dukie564
dukie564's Avatar
1995 XJ Cherokee
hmmm...i found two separate part numbers and descriptions in the parts guide, and thought that it was the same for all late model XJs with the temp gauge. Disregard my post i suppose. Learn something new every day.
dukie564 is offline
Temperature Sending Unit 2000 4.0 ??? gac17 XJ Cherokee Technical Forum 3 01-14-2010 04:55 PM
My oil guage is acting up and i don't think it's the sending unit kruucks XJ Cherokee Technical Forum 6 04-29-2009 09:54 AM
oil pressure sending unit, coolant temp unit h2rescue XJ Cherokee Technical Forum 6 01-31-2006 09:23 PM
Temperature sending unit location... ChesterWilliams XJ Cherokee Technical Forum 2 03-19-2005 03:06 PM
Newbie Intake Air Temperature sending unit question xhek XJ Cherokee Technical Forum 4 10-30-2004 03:07 PM
