where is my coolant temp sensor??
| Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com | Poison Spyder Brawler Rockers! |
#1 | |
well it's a 1998, and after thorough searching, everyone says it's on the drivers side of the engine almost all the way back there. but in my case i just have a flat spot there. if you don't beleive me i'll take a pic to prove it.
anyway, it's a 1998 engine so where is my temp sending unit? thanks in advance
97 xj 44 front, detroit, alloyed 60 rear, detroit, 35 spline alloyed 35" beadlocked km2's 3" midarmed more bells and whistles than you can shake a stick at |
#2 |
Guage probably operates off the sensor in the thermostat housing if there's not a sensor in the back of the cylinder head.
1997 VW Jetta - Daily Beater <---Totaled, seeking replacement DD 2004 GMC Envoy - Wife's Ride |
#3 |
Mine was on the drivers side back corner ust behind the valve cover, with a purple wire plugged into it.
#4 | |
anyway, the trick is it's a 1991 with the engine outta a 1998. could i just wire my guage to the sending unit on the t-stat housing ( the one that operates the electric fan) would this be a reliable reading/work?
#5 |
or how about taking the t-stat housing off and drilling and tapping a hole to accept the stock 1-wire sending unit
#6 |
bump for other ideas?
#7 |
Depends on how much work you want to do. If it were me I would drill and tap the cylinder head on the flat spot where the older units had the sending unit for the guage. It's a standard pipe thread and iron is easy to tap. Of course you would want to flush your cooling systen afterwards to get out andy metal chips
[B]JoBo[/B] Columbus, Ohio USA 2006 KJ CRD [COLOR="Blue"]Atlantic Blue Pearl Coat[/COLOR][COLOR="Black"] Limited[/COLOR] 2000 Cherokee Classic with factory 16" wheels |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
