Where to find vacuum system diagram? - JeepForum.com
post #1 of 8 Old 07-16-2010, 11:04 PM Thread Starter
afdude
I am at a loss I have searched for diagrams for the vacuum lines under my hood and the one I found is vague and not really helpful. Does anyone know where I can get some decent diagrams?
afdude is offline
post #2 of 8 Old 07-17-2010, 01:49 AM
Flyordie
1985 XJ Cherokee
Well, if it was a 1985, I have a diagram kit from Little Jess Jeep in Quincy, Ill. They were nice enough to photocopy what they had for my model year. (They are like the only licensed dealership for Jeep within 100 miles of me.)
Your best bet is to get to a Jeep dealership and ask them to photocopy the vac line diagrams they have for your model year.
Flyordie is offline
post #3 of 8 Old 07-17-2010, 02:37 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Might be a long shot but if you post a link to a picture of it, maybe someone can look under their hood and tell you where it should go.
Edit: After another read I realize you weren't asking a question about a specific line.
***Chris***
chris87xj is offline
post #4 of 8 Old 07-17-2010, 06:45 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I've seen one somewhere. Can't think of it now.....................
cruiser54 is offline
post #5 of 8 Old 07-18-2010, 10:06 AM
Paradise XJ
1988 MJ Comanche
If your year is anything like this (My 88 and my 90 are just like this) it should help.
Rear CCV to intake manifold (one line), MAP to throttle body (one line), fuel pressure regulator to manifold (one line). Front vac harness: Large line from valve cover to air box, large line in intake tube to fuel cannister. Two small lines to manifold fitting, one to EGR solenoid then out of solenoid to EGR. One out of rear of airbox to front vac motor of airbox.
With an after market intake (K/N etc.) you only need the EGR route and the front valve cover to intake lines. The others can be eliminated or plugged at the harness connection. The other (larger fitting) towards the rear of the manifold behind the TB for th brake booster. Hope this helps you.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #6 of 8 Old 07-18-2010, 01:27 PM
oderalxjlaredo
There are a few diagrams similar to the one above floating around the internet, including a handful of helpful things at this one French site. I don't want to post links for fear of the banhammer, though. PM me and I can point you in the right direction.
by the thing that spins when you drive underneath
oderalxjlaredo is offline
post #7 of 8 Old 07-18-2010, 07:28 PM Thread Starter
afdude
That seems to be the only diagram i can find, im looking 4 where the vacuum lines for the hvac hook up and if there are any vacuum lines on my tranny and where they go..in the above diagram there is a vacuum fitting that doesnt have anything hooked up to it does anyone have anything hooked up to it or is it just plugged?
afdude is offline
post #8 of 8 Old 07-19-2010, 06:21 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
That vacuum fitting is possibly the source port on the intake. From it a hose runs across the firewall, forward on the front inner fender, behind the bumper, to the vacuum reservoir. Returning from the vac res is a line that runs to cruise control and through the firewall on the passenger side to your HVAC stuff. Coming back out of the firewall at the same location is a purple plastic vac hose with a 90* rubber elbow which attaches to your heater control valve.
diagram , jeep xj , vaccuum lines , vacuum lines , vacuum system
Looking for vacuum diagram for 95 xj ilovjeep XJ Cherokee Technical Forum 3 03-28-2011 03:09 PM
89 4.0 Vacuum Diagram bmdsoccerbum XJ Cherokee Technical Forum 0 08-05-2009 03:48 PM
Need vacuum diagram wernettejr XJ Cherokee Technical Forum 4 03-17-2008 10:54 PM
Vacuum Canister & Vacuum Diagram saxj XJ Cherokee Technical Forum 9 05-06-2005 02:08 AM
vacuum diagram JVracer04 XJ Cherokee Technical Forum 3 03-07-2005 10:45 AM
