Quantcast Where do I run Hella Wires for Roof Rack - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Where do I run Hella Wires for Roof Rack
Truck-Lite's New LED Headlamp SeriesCURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee!Poison Spyder DeFenders™ - "Tubeless" Jeep Fende
Old 07-08-2007, 10:07 AM   #1
MoparOrNoCar
1990 XJ Cherokee
Like the title says, is there a small hole somewhere to run the wires down.
Please help!!!
MoparOrNoCar is offline   Reply With Quote
Old 07-08-2007, 10:20 AM   #2
paulmatyn
paulmatyn's Avatar
1992 XJ Cherokee
drill some holes through the roof, then seal the hole. or you could run them down the side into the door jam.
Originally Posted by Beefstew View Post
brain guts all over the windshield!!!!!!!!!!!!!!!!
Originally Posted by WillysEdition04 View Post
After reading 7-8 of your posts I've come to the conclusion that you may be mentally retarded, which is why I won't ask what "brain guts" are.
Originally Posted by Duck Dodgers View Post
I'd rather take the chance and belive in God than take the chance and not.
Cuz ya got nothing to lose by believing, but ya sure might if ya don't.
White Jeep Club Member-2027
paulmatyn is offline   Reply With Quote
Old 07-08-2007, 11:19 AM   #3
zatch83
1992 XJ Cherokee
I drilled a small hole in the roof through a screw hole the holds on the luggage rack. I don't have a light bar...just mounted them on the rack. I pulled out the rubber thingy and hid the wires in that trough...ran them over to the driver's side...down that hole that I took the screw out of...then down the post with the driver's seat belt on it...then along the floor and up into the dash area...I had a toggle switch that I put between the headlight rheostat knob and the rear defrost switch.
Hope this helps
I wish I could post pictures...sorry.
... /_(_)_(_)_(_)_(_)_/
...|[_____________]|
.//_____Jeep____//
|[O]||||||||||[O]|
zatch83 is offline   Reply With Quote
Old 07-08-2007, 11:20 AM   #4
zatch83
1992 XJ Cherokee
oh yeah...and put a little caulking in the hole with the wire
.//_____Jeep____//
|[O]||||||||||[O]|
Old 07-08-2007, 03:19 PM   #5
zatch83
1992 XJ Cherokee
just happened to think of something else...
I ran a ground wire from my lights to the adjacent screw on the roof rack. I just backed it out a little bit, put a crimp connector clip thingy on the end of the wire, and screwed it back down.
.//_____Jeep____//
|[O]||||||||||[O]|
Glock Forum
