Where is coolant Temperature Sensor on 1989 model? - JeepForum.com
post #1 of 10 Old 06-25-2006, 08:31 AM Thread Starter
clifsmith
Where is coolant Temperature Sensor on 1989 model and does it control the computer for fuel / air mixture? My haynes manual shows a 1991 sensor on the thermostat housing, but mine is not there.
Thanks!
clifsmith is offline
post #2 of 10 Old 06-25-2006, 09:19 AM
Scrub
Scrub's Avatar
2012 KK Liberty
there are 2 sensors, one is in the radiator on the driverside a little more than half way down, and the other in in the top of the head on the driverside almost all the way back.
89 XJ 4door - Limited - AW4 - NP231 - 180K - 31's - About 5" Lift - Trimmed - GONE!
2012 Jeep KK Liberty Sport - Stock for now
Scrub is offline
post #3 of 10 Old 06-25-2006, 01:43 PM
BrettM
the one in the radiator is only for the electric fan if yours came with one. the one at the very back driver's side of the head goes to the dash guage, and I think a different one is used for a guage versus idiot lights.
pushbutton and paddleshifters available now!
BrettM is offline
post #4 of 10 Old 06-25-2006, 08:32 PM
JoeShmoXJ
JoeShmoXJ's Avatar
1989 XJ Cherokee
Quoted for truth, this man has it right. Brett: what would be the wait on a joystick? been looking at your stuff on naxja.
1989 XJ
4.0 / AW4 / 242 / RE 5.5"
30 Front: Chromo Shafts/Joints/4.88's.
44 Rear: Aussie/Crown Vic Disks/4.88's
JoeShmoXJ is offline
post #5 of 10 Old 06-25-2006, 08:38 PM
ChaoticBastard
Its supposed to be on the thermo housing.Thats where my 89 was.
2009 Mustang GT Premium
2012 JK Sport
MetalHead Jeep Club Member #33
Originally Posted by kairo
what's wrong with bombing poor people? It has all the awesomeness of bombing combined with removal of crime. It's like a win win situation.
Unwad your panties
ChaoticBastard is offline
post #6 of 10 Old 06-25-2006, 08:43 PM
anony91xj
The coolant temp sensor that sends a signal to the PCM on the Renix 4.0's is located in the side of the block, driver side, below the manifolds.
1998 VW GTI 2.0
anony91xj is offline
post #7 of 10 Old 06-25-2006, 08:45 PM
ChaoticBastard
Yes you are correct.But there are 2
2012 JK Sport
Unwad your panties
post #8 of 10 Old 06-25-2006, 09:10 PM
JoeShmoXJ
JoeShmoXJ's Avatar
1989 XJ Cherokee
To recap, i'll summarize. There are three sensors:
Gauge - Located on drivers side, rear of head. (one wire)
Elec. Fan - Located on drivers side, radiator, near lower hose (2 wires)
PCM - Located on drivers side, on the block underneath the manifold.
There should be no sensor in the thermostat housing, that came in 91+
1989 XJ
post #9 of 10 Old 06-25-2006, 09:28 PM
BrettM
sending ya a PM
BrettM is offline
post #10 of 10 Old 06-25-2006, 11:14 PM
ChaoticBastard
My 90 waggy with the renix had that sensor on the housing.I remember when I changed out the water pump.The system wasnt upgraded .Maybe they just swapped housings earlier.But it also had the plug in it
2012 JK Sport
Unwad your panties
Coolant Temperature Sensor se7vn XJ Cherokee Technical Forum 2 10-09-2007 01:17 PM
coolant temperature sensor Ex-Jay XJ Cherokee Technical Forum 2 06-02-2007 03:32 PM
coolant temperature sensor scubaguy19 XJ Cherokee Technical Forum 1 02-26-2007 09:34 PM
coolant temperature sensor 93_zj XJ Cherokee Technical Forum 7 05-26-2005 12:14 PM
Coolant Temperature Sensor Wiring Bruceski XJ Cherokee Technical Forum 1 03-03-2003 02:35 PM
