Quantcast Where is the best place to run wires for a roof mounted light bar? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Where is the best place to run wires for a roof mounted light bar?
Old 10-15-2007, 12:21 PM   #1
Nukin Futz
Junior Member
Nukin Futz's Avatar
I want to put a light bar on my XJ, but I'm not sure of the best place to run the wiring.
Thanks
Nukin Futz is offline   Reply With Quote
Old 10-15-2007, 01:01 PM   #2
collkid
you mean into the cab? i drilled a small hole, and covered it by some sealent
2000 Jeep Cherokee. 4.5', Long arms, Bumpers front and rear, Winch.
1992 Toyota Paseo DD 35+ MPG
Colorado Member #89
collkid is offline   Reply With Quote
Old 10-15-2007, 02:49 PM   #3
Moose_God
1994 XJ Cherokee
I drilled a hole in the roof right next to the lengthwise runner on the factory rack and from there ran the wires under the headliner and down the A-pillar. Don't have the lights up there right now, so there's a rubber plug siliconed in the hole for now. I'm thinking about finding a thru-hull marine connector to go up there when I put the light bar back on...
94 Cherokee Sport 4wd (converted from 2wd), AW4, NP231 w/SYE, 6" bastard lift, RC drop brackets, IRO trackbar, 33x12.5 Goodyear MTRs, HDoffroad subframe connectors, prerunner front bumper, homebrew rear bumper, flowmaster 40, 96 booster swap., upgraded headlight harness, 4.56 gears (finally!!!)
Moose_God is offline   Reply With Quote
Old 10-15-2007, 09:30 PM   #4
Pincombe
I did the same thing. I drilled a hole just inside the end cap for the roof rackrail above the drivers head and ran it under the head liner and then down the "B" Pilar. I gooped it up with RTV and stuck a rubber grommet with some more RTV. Been like that for 3 years now. We get our fair share of rain and snow in West Michigan and it has not leaked yet. I know it sounds crude to drill a jole in your roof but it's best way to run wires out of sight.
2000 XJ, 4.0L, 3" Rough Country, T/C lower, 31" Firestone Destination MTs, K&N,bored TB, Dynomax Cat back, Raybestos Brutestop slotted rotors, Raybestos Ceramic pads / shoes, Surco Safari Basket with 6 Eagle Eye 5" 100watt lights, AVS bug deflector,Nates 4x4 custom front bumper, Tail shades, Viper security w/ remote start. Clarion CD, Kenwood EQ, 3 Kenwood amps, 2 sets of MTX componets, and 2 10" MTX Subs.
Pincombe is offline   Reply With Quote
Old 10-15-2007, 09:33 PM   #5
Pincombe
I forgot to mention I used a 4 pin trailer wire harness as well, so I could remove my safari basket if needed by just unplugging the connection. 1 common ground and three circuts with 2 lights on each. Works great. Each circut has it's own switch runnng 2 lights each. Four lights facing forward and 2 in the rear.
Old 10-15-2007, 09:34 PM   #6
lifted92xj
1992 XJ Cherokee
alro just drilled a small hole, i put in connectors next to it too so if i wanted i could just unplug it and slide the light bar right off
big lift, sick tires, awsome accessories, alot of custom work.
my jeep won the war, your honda mows my lawn
lifted92xj is offline   Reply With Quote
Old 10-16-2007, 08:27 AM   #7
lcarney91
Speaking from the Fire/Law Enforcement perspective, a large percentage of emergency light bars are connected through a hole in the roof. Most installers just drill a large hole, place a rubber grommet to protect the wiring, and then use a half tube of silicone (at least thats what it looks like) to seal the opening. I have seen these things last for years and years and never leak. Also, if you want to add more lights/wires, the silicone peals off easily, and allows you to fish more wires through.
1999 XJ.....
Stock, with some intake/exhaust work
"The ol' family truckster"
lcarney91 is offline   Reply With Quote
Old 10-16-2007, 10:19 AM   #8
webdog
DirtBound Offroad
webdog's Avatar
1990 XJ Cherokee
haha yup, my XJ was a school security vehicle when it was first bought and there are like 6 holes in the roof, one big one and a bunch of smaller ones from light bars.
They just put plastic plugs in and RTV it in and it has not leaked on me yet.
The good thing is when i get the lights for the roof i wont have to drill since the holes are already there.
webdog is offline   Reply With Quote
Old 10-16-2007, 11:10 AM   #9
NYCXJ90
1990 XJ Cherokee
if you don't want to drill you can run them up trough the a pillar, under the weatherstripping and wrap them around the rain gutter.
works but not as clean as a hole in the roof.
'90 XJ Laredo /33"X12.5" Retreads/ RE 3.5" Super Ride
NYPD Jeep Club Member #2
Marine Corps Jeep Club Member #3
So I tell the swampdonkey to sock it before I give her a trunky in the tradesman's entrance and I have her lick me yardballs.
NYCXJ90 is offline   Reply With Quote
Old 10-16-2007, 11:45 AM   #10
UKJeepThang
What sort of connectors are you guys using? And what's the best type from a waterproof perspective? Could somebody post some pics up so I could have a look?
I've got to re-wire my 2 existing Daylighters (plus 2 more to be added) through a hole in the roof. Makes sense really but I've never thought of using a connector before.
1998 XJ
RE 4.5 inch superflex lift, RE GEN2 disconnects, 15x8 Crager 352's, 33x12.5x15 BFG MT, ARB Lockers Front and Rear, 4.56 Diffs, Cut & Tap Short Shaft Conversion, CV Rear Prop, B&M Transmission Cooler and Gauge, Bushwackers Cut-Outs, Skid Row Armor, AJ's SuperRails, LeBaron Hood Vents, KargoMaster Rack, Safari Snorkel, KC Daylighters, Midland CB, Brantz Navigation
Loads a mud!!
UKJeepThang is offline   Reply With Quote
Old 10-16-2007, 11:52 AM   #11
JohnnyX
Heres a write up i did a while ago...
http://www.jeepforum.com/forum/showthread.php?t=359255&highlight=roof+rack+light+ wiring
hope this helps.
North Jersey Jeep Club Member- #83
www.northjerseyjeepclub.org
the rig:
http://img402.imageshack.us/img402/8980/jeep2xq0.jpg
CHECK OUT MY BAND- www.myspace.com/myrtleave
JohnnyX is offline   Reply With Quote
Old 10-17-2007, 05:38 PM   #12
UKJeepThang
Hi johnnyx
I followed your instructions and did the same routing with my lights but I now want to route them through the roof and I'm interested in what sort of connectors people are using to enable me to take the roof rack off and disconnecting all four lights at the same time.
1998 XJ
Loads a mud!!
Old 10-17-2007, 06:03 PM   #13
wbacon
1988 XJ Cherokee
Don't know much about wiring. Where did you hook up your power wire...fuse box?
1988 Cherokee 2Dr, 4WD, 4.0 LTR
wbacon is offline   Reply With Quote
Old 10-17-2007, 09:09 PM   #14
sundevilkid
Running 6 100W Hella lights (KC Daylighter knock offs... Are they really knock offs if they are Hella???)
I did the same thing, drilled a hole in the roof, ran the grounds to the bar, and the leads through the hole. 6 14 gauge wires needed about 1/2 hole. Ran them down the drivers side pillar after putting them through the hole, tucked them away behind the dash then ran them through a stock hole/grommet in the firewall. Ran them along the backside of the engine compartment along the fire wall. I also used that plastic tubing to keep it looking clean (for the most part). Then installed 3 relays. 2 lights per relay. Each relay is connected directly to the battery. I have a switch that shares it's power source with my CB. Also running direct from the battery. It flips on all three relays. I'll throw pics up in my gallery tonight.
1996 XJ Classic
My sig got too long. So we'll just say it's Friggin' Sick.
sundevilkid is offline   Reply With Quote
Glock Forum
