when i put my 1995 jeep cherokee sport in drive it clunks - JeepForum.com
post #1 of 11 Old 06-16-2010, 09:34 AM Thread Starter
lionsdetroit
1995 XJ Cherokee
When ever i put my jeep in drive it makes a clunk noise i took it to a machanic he said its a jeep thing is that true? u joints are fine
lionsdetroit is offline
post #2 of 11 Old 06-16-2010, 10:09 AM
99Greenmachine
mine clunks...I've always understood it to be a Chrysler trademark...maybe our tranny mounts are worn out
'99 XJ Sport
Thank You Hooligan!!!
[SIZE="4"]XJ Dana 44, Yukon 4.56 D44 Gears, LeBaron hood vents for sale
99Greenmachine is offline
post #3 of 11 Old 06-16-2010, 12:07 PM
lowicz96
1995 XJ Cherokee
My 95 sport makes all kinds of chrysler clunks, Every now and then when its getting bad i remove the read driveshaft and pack the slip yoke with grease. Makes it quit again.
Project/DD - 95' Cherokee Sport, 2 Door, Converted to 4x4, AX-15, NP231, Black and lots of other goodies
88' Cherokee Limited - RIP
Sold - 96' Cherokee Sport 4x4, 2 Door, AW4, NP242, Its the girlfriends now!!
lowicz96 is offline
post #4 of 11 Old 06-16-2010, 12:17 PM
93gc40
This is NOT a Jeep thing... It can happen with any automobile.
Causes of type of clunk in a XJ; low or excessive transmission fluid, worn U-joints, DS Slip joint needs lube, Worn Spring bushings, miss adjusted rear brakes, excessive play in rear differential gears, loose exhaust hangers, worn motor or Trans mounts, worn shocks, loose shock mounts.
96 XJ 4.0 / 231 / 3.5" JY Lift/ 31" BFG /.....
93 VT1100 - Harley killer.
97 ZJ 4.0 / 242 / Stock
93 ZJ 4.0 / 2"BB / Wranglers / RIP-Gone but not forgotten.
If it aint dirty, it aint a JEEP, it's just a SUV.
93gc40 is offline
post #5 of 11 Old 06-16-2010, 12:27 PM
lowicz96
1995 XJ Cherokee
or a new jeep
lowicz96 is offline
post #6 of 11 Old 06-16-2010, 12:37 PM
99Greenmachine
I like to shift mine into N when there are people with me, it really seems to help the issue
'99 XJ Sport
post #7 of 11 Old 06-16-2010, 12:40 PM
Metzroth
Lots of vehicles do it...the most common reason has already been mentioned and that is excessive play in the rear end. Have someone shift it into drive while you watch the drive shaft turn back by the rear end. Obviously they don't need to drive with you under the jeep, just shift into drive while holding the brakes.
2000 XJ Classic - 33" GY Duratracs, 15x10 Cragar V5s, Crown HD springs, Clayton adjustable shackles, OME Nitrocharger Sport Long Travel Shocks, JKS Discos, extended brake lines, 2" poly spacers in front with V8 ZJ springs, Powerslot Rotors, Hawk HPS Pads, Hella E-Code headlight housings, Narva 100/130 Bulbs, Olympic Top Hat Rack, etc.
Metzroth is offline
post #8 of 11 Old 06-16-2010, 02:07 PM
98beast
check your ujoints to make sure then check your tranny fluid then check your tranny mounts.
OOHHRRAHH water dogs!
the shovel will always be known as plan B
"Complete the Mession by using the boother pump and then tie it off to the pond."
98beast is offline
post #9 of 11 Old 06-16-2010, 02:16 PM
cbenez1
"Yeah", "What he said" Except you left out the possibility of automotive gremlins with little hammers hitting your floor whenever you put it in gear. The solution to that problem is driving thru deep water and or mud, alot. They hate that.
cbenez1 is offline
post #10 of 11 Old 06-16-2010, 04:02 PM
Mighty Thor
If the u joints in the drive shaft are not the cause of the noise then probably you also have some play between the various parts inside the rear Differential. They are normally set up so that there is very little room between the parts. When one moves it almost instantly makes the next one move etc. When things are set up correctly as soon as the Drive shaft starts to turn everything else starts to turn and that includes the wheels. When things get older the space between the gears increases due to wear and it takes a while for things to catch up. as each piece hits the next it causes noise.
As an example, try this, take a piece of chain and stretch it out across the lawn so that each link is tight against the others. When you pull on the end the far end will start to move almost immediately and there wont be very much noise. Now take the same chain and lay it out so that all of the links are loose and not tight. Now pull the end and it takes a while for the other end to move and you will hear noise as each link bangs into the next one.
Now think about that chain hooked to a car at one end and you start to pull by walking with the chain in the other direction. When the chain is tight you will not get very far or very fast before you have started to apply smooth force to the car. When the chain is loose you may be moving pretty good by the time the chain goes tight and there will be a pretty good jerk at the other end of the chain when it finally goes tight.
Is that supposed to look like that?
Mighty Thor is offline
post #11 of 11 Old 06-16-2010, 08:54 PM
cj7jeeps
Have had 3 diff xj's do this to me has always been the rear u joints.
cj7jeeps is offline
DRL module 1995 Cherokee Sport trevor-m XJ Cherokee Technical Forum 7 07-14-2017 02:00 PM
Changings front end (not drive shaft) u joints, 93 Cherokee sport killface56 XJ Cherokee Technical Forum 2 09-16-2008 03:10 PM
Hot wires 1995 Cherokee Sport 4.0 I-6 jonelsr XJ Cherokee Technical Forum 0 05-18-2008 11:10 AM
1995 Jeep Cherokee Sport Inline 6 Magus2727 XJ Cherokee Technical Forum 14 03-28-2007 08:10 AM
Tranny issues 97 jeep cherokee Sport, Clunking when going into drive and reverse Cachee0 XJ Cherokee Technical Forum 4 08-19-2004 06:57 AM
