When do you use the lower gears on the automatic transmission? - JeepForum.com
post #1 of 14 Old 10-21-2009, 12:44 PM Thread Starter
yooper2001xj
I've searched for awhile on this with no luck.
Can anyone explain when to shift into the lower gears, 3,2,1 on the auto transmission? When to use and not to use them? Any info or links explaining this would be great.
Thanks
yooper2001xj is offline
post #2 of 14 Old 10-21-2009, 12:48 PM
foggybottombob
I use them for long downhill sections on the highway in mountainous terrain to slow down without smoking my brakes. And I use them off road to pick an appropriate speed range for the trail surface.
foggybottombob is offline
post #3 of 14 Old 10-21-2009, 12:49 PM
JeepCherokee513
1994 XJ Cherokee
I hardly ever use the lower gears unless im 4 wheeling, and even then i mostly keep it in Drive. unless im going up a somewhat steep hill then i'll throw it down in 1-2.
JeepCherokee513 is offline
post #4 of 14 Old 10-21-2009, 12:54 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Use OD (overdrive) for all your daily driving.
Use 3 for towing.
Use 3 for downhill sides of mountain roads, the engine compression will help slow the vehicle. Use 3 for very steep uphill mountain roads like Vail Pass.
Use 3 for 4x4 trails. Use 1-2 for very step downhill 4x4 trail sections. The engine compression will help slow the Jeep without using the brakes
CJ7-Tim is offline
post #5 of 14 Old 10-21-2009, 12:55 PM
Greenz
X2
Greenz is offline
post #6 of 14 Old 10-21-2009, 12:57 PM
Gnl.Weirdness
1-2 is nice for steep roads with snow/ice on them as well.
Gnl.Weirdness is offline
post #7 of 14 Old 10-21-2009, 01:45 PM Thread Starter
yooper2001xj
When towing in 3, is there a max speed? I assume when towing something light, like a small boat, drive is fine. When towing a U-Haul loaded, down shifting to 3 would be a good idea.
post #8 of 14 Old 10-21-2009, 01:47 PM Thread Starter
yooper2001xj
Use 3 for towing.
post #9 of 14 Old 10-21-2009, 02:57 PM
natetuff
I would more or less obey posted speed limits, maybe even 5mph under depending on what you are towing.
Your RPMs should tell you the appropriate speed in 3rd.
The main thing to remember about towing is not just getting up or traveling at a certain speed, it's slowing down/stopping. Similar to snow/ice conditions,
you can go as fast as you want, but good luck stopping.
natetuff is offline
post #10 of 14 Old 10-21-2009, 03:21 PM
lowicz96
1995 XJ Cherokee
I've always heard you don't put it in overdrive while towing because when the torque converter locks up, it puts to much stress on the trans and it will overheat from the pump not pumping fast enough.
1 - 2 for steep incline/declines and some wheeling
3 - towing
OD - regular driving
But like what natetuff said its not how fast you can pull something, its getting it stop. I've pulled an XJ with another XJ and it pulled great but was scary as **** having to stop it in traffic
Project/DD - 95' Cherokee Sport, 2 Door, Converted to 4x4, AX-15, NP231, Black and lots of other goodies
88' Cherokee Limited - RIP
Sold - 96' Cherokee Sport 4x4, 2 Door, AW4, NP242, Its the girlfriends now!!
lowicz96 is offline
post #11 of 14 Old 10-21-2009, 11:20 PM
Greenz
I towed ~2500# trailer across the country mostly in OD. In the mountains, used the gears to help with speed control. Plenty of snow and ice in the rockies made me stay cautious.
Did not have any overheating issues with the tranny nor had any breaking problems. I did install a tranny cooler before the trip and it was in December so that may have been the difference.
Hardly new it was back there except it was wider than the jeep and the mirrors barley worked with it.
Frickin sand on the road sand blasted my rockers, rear flares, windshield, and tire width pattern on the front of my trailer. Thanks Idaho!
Greenz is offline
post #12 of 14 Old 10-22-2009, 01:29 AM
Luke94XJ
1994 XJ Cherokee
I occasionally tow 1800 lbs of Jet skis/trailer, leaving it in 3 definitely helps, especially in slightly hilly sections. In most truck manuals it will tell you to take the trans. out of overdrive.
Luke94XJ is offline
post #13 of 14 Old 10-22-2009, 02:36 AM
CJ7-Tim
CJ7-Tim's Avatar
Whatever the speed limit is.
CJ7-Tim is offline
post #14 of 14 Old 10-22-2009, 06:28 AM
dcorn
My drive from the DC area to Snowshoe mountain ski resort is full of pretty big mountains, so this time I left it in 3rd going up and down the mountains. Needed the extra gearing to get up the hills and used the engine braking so my brakes weren't burning up on the way down.
Occasionally, if I'm towing the wave runner locally and not going over 50mph, I'll keep it in 3rd.
Last time I went wheeling, I'd put it in 1st going down really steep hills and it gives you tons of control because you barely have to hit the brakes and you just crawl down the hill. Helps more if you have shorter gears as well.
2014 Jeep Grand Cherokee Summit
dcorn is offline
Clunking When Shifting into lower gears Gnl.Weirdness XJ Cherokee Technical Forum 8 03-18-2009 04:38 PM
Automatic transmission w^rl0rd XJ Cherokee Technical Forum 1 01-21-2005 06:10 AM
chatter from tranny in lower gears? chevelle396 XJ Cherokee Technical Forum 5 09-16-2004 08:39 AM
automatic transmission? tim@kollmorgen XJ Cherokee Technical Forum 8 08-25-2004 09:16 PM
does anyone have their old gears from an automatic? iamthemellowman XJ Cherokee Technical Forum 4 03-12-2003 03:46 PM
