Wheel Spacers??? - JeepForum.com
post #1 of 16 Old 10-30-2011, 06:54 PM Thread Starter
OMJinTOL
Wheel Spacers???
I have a 99 XJ with a 2" lift. I'm getting a great deal on a set of 265/75/15 on canyon rims. Do I need wheels spacers? Are there any handling advantages by using them if you don't need them. I'm new to mods on my Jeep, so any help is appreciated.
OMJinTOL is offline
post #2 of 16 Old 10-30-2011, 07:28 PM
XJcruiser
they may rub the stock LCAs, but you can always just adjust the steering limits. They do affect handling, but not that much. Its more strain on the steering and bearings though.
Friends dont let friends do DUBS.
XJcruiser is offline
post #3 of 16 Old 10-30-2011, 07:29 PM
donthelegend
Wheel spacers are used to correct the backspacing of wheels, generally to fit larger tires without rubbing. They introduce issues of their own, like doubling the number of lug nuts you have to torque and making sure they don't loosen up, as well as added leverage and stress on the wheel bearings. Lots of people run them without issue, but if you don't need them, they offer added complexity without any advantages.
I don't know the specs of canyon rims so I can't comment on whether or not you'll need spacers, but if you don't, I wouldn't recommend running them.
donthelegend is offline
post #4 of 16 Old 10-30-2011, 07:44 PM Thread Starter
OMJinTOL
Thanks for the feedback!
OMJinTOL is offline
post #5 of 16 Old 10-30-2011, 07:57 PM
XJcruiser
canyons= 15x8 w/5.25"BS
post #6 of 16 Old 10-30-2011, 08:53 PM
Azzy
If you maintain them properly, and i would suggest ones that are hubcentric, they can get you teh same result as getting a tire with less backspace.
Same strain on the hubs and bearings as going with another wheel. Some people will try to sell you on a world of evil spacer voodoo, but if you look at the physics of it, a good quality one will do much the same. Dont get any that do not have their own lugs, torque them correctly, and check them after installation and running, like you would any other hardware.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #7 of 16 Old 10-30-2011, 09:43 PM
Azzy
I would add that the cost of good spacers may be more than getting a good set of rims with the proper backspacing. There is also tire installation and balancing to consider.
Could it be a good stopgap? maybe.
Azzy is offline
post #8 of 16 Old 10-30-2011, 11:38 PM
Planetcat
2010 WK
I run the Rough Country 1.5" spacers on my '90 XJ. 30x9.5R15's on OE limited wheels (not sure what they're called - the BBS style ones). Anyways, they rubbed like crazy in the front when turning. Spacers cured the problem and gave me a wider stance. I run them on my WJ too. I highly recommend them for larger tires on stock rims, due to the deep backspacing. The RC's and Spidertrax ones are well made, and if torqued down properly with red locktite, won't cause any problems.
2010 WK Laredo 5.7L, 2004 WJ 4.7L (totaled), 1959 CJ-5, 1996 XJ (sold), 1989 YJ Wrangler 4.2L (Sold)
Planetcat is offline
post #9 of 16 Old 10-30-2011, 11:52 PM
Wearingthin
OMG your axles are gonna crack in half if you use spacers and there are so many parts that you'll go crazy and postalize the nearest shopping center ahhhhhhhh!!!!!
Seriously though. Spacers are the only way I was able to use my Moabs on my size tires. Locktite the *****es and you're good to go. Check em when you rotate your tires and you check your other lugs, takes you an extra 10 seconds a hub.
Spacers don't put anymore strain on your components than a set of similarly backspaced rims.
Its like the difference between a diaphragm and a condom, two different ways to attack the same problem
Patriot Blue XJ 4x4
RE 4.5" | 305/70/16 MTR K
Wearingthin is offline
post #10 of 16 Old 10-31-2011, 08:03 AM
Azzy
Why red loctite?
Ive seen it recommended lots of places, but every steering component I have pulled stock from jeep was held together with correct torque and blue locktite.
Red is for when you never want to get it apart again.
Blue is for when you just want a bit of heat to get it off there again.
Purple / green is for minor vibration resistance.
Anyone point to more than "I just heard it" or "better safe than sorry" argument? Thinking about it, i never loctit-ed my wheels, have you? What about when you need to do something like... change breaks, or some trail repair? Pulling out the torch when out there, and then having to swap out now annealed components?
Azzy is offline
post #11 of 16 Old 10-31-2011, 08:13 AM
oldmanscherokee
1992 XJ Cherokee
This ^
Spacers on stock wheels give you the back spacing of most aftermarket wheels. Either way you need the backspacing to fit the bigger wheels properly without them being tucked into the wheel wells to much. I ran my 4.5 lift with the 32 x 11.50s without spacers on stock wheels for a while. It worked, I had to adjust the steering bumps, and the rear tires were about 3/4 of an inch from the springs. After the spacers they fit so much better and the truck had more of a stable stance.
full time tech for chevy, part time trail rider
95 Ford Lightning (sold), 09 Caddy CTS-V, 04 Buell Firebolt XB12R w/true flame paint, 00 harley XL chopped, 81 Trans Am, 85 K5 Jimmy 4 inch w/35s, 92 cherokee
10,000 original miles
4.5 inch RC lift
32 11.5 bfg muds
oldmanscherokee is offline
post #12 of 16 Old 10-31-2011, 12:51 PM
Planetcat
2010 WK
Originally Posted by Azzy View Post
Why red loctite?
Spidertrax provided a tube of red locktite with their spacers, so I put it on the rough country ones too. In reality, I think it's just extra precaution, because the nuts are flanged and seat tight into the aluminum spacer, torqued at 90 lbs. There really is no reason to remove the spacers unless you are pulling the axle shafts out or getting a wheel with a shallower back spacing. Maybe to do the rear drum brakes they might have to be removed, but not on disc brakes.
post #13 of 16 Old 10-31-2011, 12:57 PM
cbordea
wouldn't you need to remove the spacer to replace the hub/bearing?
88 MJ I6 4x4 Stock my hauler - Sold
98 XJ I6 4X4 Stock my son's DD
06 12V Purple Barbie Jeep my daughter's DD :-)
cbordea is offline
post #14 of 16 Old 10-31-2011, 01:05 PM
Azzy
Or to replace a rotor. Or a busted axelshaft.
Last one is less likely.
Azzy is offline
post #15 of 16 Old 10-31-2011, 04:51 PM
Planetcat
2010 WK
Yeah, probably replacing brake pads is the only thing you can do without taking them off. I've never had to do anything but brakes on my jeeps, but I guess it's inevitable.
wheel spacers? jfsjr92 XJ Cherokee Technical Forum 4 01-25-2011 06:36 PM
wheel backspacing vs. wheel spacers silverxj2001 XJ Cherokee Technical Forum 4 07-17-2010 10:24 AM
wheel spacers???? amryjoe XJ Cherokee Technical Forum 4 05-18-2010 01:41 PM
Wheel spacers? eclipse27 MJ Comanche Technical Forum 5 04-08-2006 02:51 PM
Wheel Spacers? Classic98 XJ Cherokee Technical Forum 8 03-23-2006 10:14 AM
