Wheel cylinder keeps blowing - JeepForum.com
post #1 of 25 Old 11-19-2013, 11:14 PM Thread Starter
teddysplxj42
So I've replaced my passenger side wheel cylinder about 5 times in the past month because it keeps blowing out on me. At first I thought that there was air in the lines, so I bled all my lines. There was a little air in it but I got it all out and hooked everything back up, and they worked until the other day when the wheel cylinder blew again. I was told maybe the proportioning valve not sending the right pressure through, I just wanna make sure of all the possibilities
teddysplxj42 is offline
post #2 of 25 Old 11-20-2013, 06:54 AM
Bobplymouth
1997 XJ Cherokee
The proportioning valve is there to allow a little more pressure to the front than the rear,
but even if all pressure was going to the front, the wheel cylinder should not blow out..
Bobplymouth is offline
post #3 of 25 Old 11-20-2013, 08:23 AM
jeepster383
Pics of how it's instaled. Shoes not adjusted corectly allowing the pins to push out all the way? Or is it just leaking from the boots? Where are you geting the replacements?
jeepster383 is offline
post #4 of 25 Old 11-20-2013, 11:44 AM
psychoteen101
Blowing out as in they start leaking or its actually pushing the pistons out of the cylinder?
1996 Jeep Cherokee- Project-- Rusty's 8in long arm, SYE kit, Teraflex driveshaft, Cragar soft 8's 15x10 with 33x12.5 Firestone Destination MT's, Eaton Tru Trac in the front
psychoteen101 is offline
post #5 of 25 Old 11-20-2013, 04:46 PM Thread Starter
teddysplxj42
It's literally pushing the piston out of the cylinder every time
post #6 of 25 Old 11-20-2013, 06:23 PM
AZ Jeff
2014 JK Wrangler
Then you have an assembly or an adjustment issue. When assembled correctly, and adjusted per procedure, the pistons CANNOT move far enough to come out of their bores on the wheel cylinder.
Are you SURE you have everything assembled correctly, with the proper parts?
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #7 of 25 Old 11-20-2013, 06:30 PM Thread Starter
teddysplxj42
It's all hooked up correctly with the right parts, I even changed that line because it broke the first time the wheel cylinder blew. They all bleed correctly and everything also
post #8 of 25 Old 11-20-2013, 06:37 PM
bigbill888
wrong brake drum?
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #9 of 25 Old 11-20-2013, 06:45 PM Thread Starter
teddysplxj42
It's the same drum I've had on it since I got it. It definitely needs new shoes for the drum. Could bad drums and shoes be doing this?
post #10 of 25 Old 11-20-2013, 07:01 PM
bigbill888
You changed the wheel cyl, but not the shoes?
All work well
post #11 of 25 Old 11-20-2013, 07:08 PM
bigbill888
before you step on the brake pedal, the brakes need to be adjusted out to the point where they just barely touch the drum when you spin it.
All work well
post #12 of 25 Old 11-20-2013, 08:56 PM
jeepster383
You are installing the drum before pushing on the Brake pedal right
post #13 of 25 Old 11-20-2013, 09:01 PM Thread Starter
teddysplxj42
I want to say yes but now that I think about it I don't actually know lol
post #14 of 25 Old 11-20-2013, 09:29 PM
jeepster383
Lol you need the drums on if u need to bleed brakes. U can't have the drums off if you push the brake pedal or youl push the pistons right out.
post #15 of 25 Old 11-20-2013, 09:39 PM Thread Starter
teddysplxj42
Lol I'm gonna get some new shoes for it and try it again, maybes that's what the problem was
