Wheel bearing going out, how tough to replace? - JeepForum.com
post #1 of 7 Old 08-20-2006, 01:03 PM Thread Starter
LXguy
Hey all:
So, I've got a flying saucer noise from the passenger side on the front end, but only at low speed. I'm fairly certain it's the wheel bearing.
There is no write-up on replacing it in my Chilton manual. How hard is it really?
Autozone wants 119.00 for the part. I imagine that means the dealer would want $500.00 to replace it. LOL!
Steve
Project Ebay XJ underway (99 Cherokee Sport)
LXguy is offline
post #2 of 7 Old 08-20-2006, 01:57 PM
JFM626
JFM626's Avatar
JFM626 is offline
post #3 of 7 Old 08-20-2006, 02:01 PM
BigBearXJ
you can get one from advance auto for $104 with a lifetime warranty
Its really not a bad job, it just requires some special tools.
Eat, Jeep and be Merry.
BigBearXJ is offline
post #4 of 7 Old 08-20-2006, 02:04 PM
Meatroach
Meatroach's Avatar
1992 XJ Cherokee
it's not too hard, you'll need a large sise deeep socket to get the wheel nut off (56mm i think) and a BFH if the bearing assembly is stuck/rusted on. it's just a swap of the part after you remove the brake assembly. I'd say if you're mechanically inclined youcould have it done in 2-3 hours (that's giving room for problems)
I used no special tools to pull the bearing.........mostly because it separated when i removed the wheel nut!!
GL!
XJ
[COLOR="Red"]3.5" Warrior coils, Full leaf packs, Skyjacker Quick Disconnects, Rear swaybar delete, Pro Comp shocks, HD Steering stabilizer, BFG AT's, 1" drop shackles, Front tow hooks,Front skid, Warn T-case skid
Meatroach is offline
post #5 of 7 Old 08-20-2006, 02:18 PM
x99j
Originally Posted by LXguy
Hey all:
Steve
when i called the dealer they wanted 360 just for one hub. not including labor. i picked up one for 108. i sure it isn't as good as the oem part, but i can replace three cheapies for the price of one oem. i think autozone carries timken brand hubs. they are one of the best on the market,
also be advised you have a 99 they have two different hub styles! one for cast and one for composite rotors. make sure you got the right hub! i know through experience trust me!
06 kj 3.7l, 6speed manual, np241 command track
91 yj 2.5l, ax-5, np 231 3 inck lift, 31'' mud rovers
12 kk 3.7L, 42rle, mp1522, d-30, 8.25.
x99j is offline
post #6 of 7 Old 08-21-2006, 12:27 AM
96JXJ
GL!
Pretty sure it is 36mm. JIM.
96@6 & 92@3
96JXJ is offline
post #7 of 7 Old 08-21-2006, 12:29 AM
BigBearXJ
and a 13mm 12pt socket.
Rear wheel bearing/axle shaft bearing replacement? kadetklapp XJ Cherokee Technical Forum 4 09-02-2008 02:06 PM
Wheel bearing, single bearing or hub assembly? Ski01xj XJ Cherokee Technical Forum 25 02-25-2007 09:10 AM
Rear whell bearing replace on D35 Catalina XJ Cherokee Technical Forum 3 11-05-2006 08:28 PM
Replace Wheel Hub and Bearing 360 bucks!! Renegade_Rick XJ Cherokee Technical Forum 4 02-20-2006 09:31 PM
91 XJ leaky front main seal, How tough to replace? BoBo XJ Cherokee Technical Forum 0 03-05-2002 03:37 PM
