What's your caster? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > What's your caster?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line50" LED CREE Light Bar Pair With Wiring KitTeraflex JK LCG PRE-RUNNER KIT! ULTIMATE OFF ROAD PERFORMA
Unread 05-04-2013, 11:23 PM   #1
Inglburt
What's your caster?
Question aimed at the ones running 35" tires and 5" or 6"+ lift. But what caster are you running? And maybe what have you experimented with and what results did you have?
Inglburt is offline   Reply With Quote Quick reply to this message
Unread 05-05-2013, 08:32 AM   #2
CJ7-Tim
Real Jeeps have dents.
CJ7-Tim's Avatar
Pinion angle is more important than caster angle. You have to balance the two, enough pinion angle that there are no vibes, and enough caster for acceptable steering. Each XJ is different, so you have to determine what angles work for your XJ.
Total US debt has increased by 70% under Obama, from $10.625 trillion on January 21, 2009 to $18.005 trillion January 1, 2015.
Progressive Liberalism: Bringing you new Healthcare ideas so wonderful, they have to include mandatory participation ......
CJ7-Tim is offline   Reply With Quote Quick reply to this message
Unread 05-05-2013, 09:14 AM   #3
foggybottombob
The only thing I have ever read that was believable regarding setting caster for large tires on an XJ said use minimum spec caster and maximum spec toe in for large tires. That makes sense to me considering all the other things I have read with respect to avoiding shimmy/death wobble. I think that minimum spec caster for an XJ is 5 degrees positive. The maximum toe in spec I have been able to find is 1/8". But I think it would make more sense to specify toe-in as an angle.
foggybottombob is offline   Reply With Quote Quick reply to this message
Unread 05-05-2013, 09:48 AM   #4
CJ7-Tim
CJ7-Tim's Avatar
At 3.5" of lift, or now at 5.5" of lift, IDK what my caster angle is, or was. I have a reasonable pinion angle with no vibes, and the steering is acceptable. All I did was dial in more toe angle. Larger tires tire may need greater toe-in than smaller tires.
Unread 05-05-2013, 11:23 AM   #5
Inglburt
Thanks for the replies, I know about the pinion angle and everything. I'm not asking what I should be running, just researching what people are using and what is working best for them. All info is good.
Unread 05-09-2013, 09:38 AM   #6
troy5118
The only way to get caster correct after lifting it is to cut and rotate the c's.
It's a pain but after doing it I have 8 degrees of caster with the correct front drive line angle. Its nice to be able to drive with one hand again on 35's
troy5118 is offline   Reply With Quote Quick reply to this message
Unread 05-09-2013, 02:18 PM   #7
sAe23
1995 XJ Cherokee
At 7" of lift, I have my pinion pointed straight at the drive shaft (each is at 10 degrees) and my caster is at 1.5 degrees.
Cutting the axle is too expensive ($600++) and adjustable ball joints only give about 2 degrees, so they wouldn't be helpful enough.
sAe23 is offline   Reply With Quote Quick reply to this message
