WHATS THIS NOISE? Timing chain or piston slap? - JeepForum.com
post #1 of 5 Old 08-22-2008, 04:50 PM Thread Starter
4.0H.O.XJ
At the front of the engine. In the timing chain area.
Used to do it ONLY when COLD, but now it is taking longer and longer for the noise to go away. Today, it didnt go away at all. Sounds like marbles in a can of light oil being rattled around. Been doing it since I bought it and has slowly gotten worse.
Yes, it sounds like a timing chain.
However, another Jeeper said: "No. a '96 timing chain is virtually indestructable. What you are hearing is PISTON SLAP."
Doesnt sound like any piston slap Ive ever heard, and with 217 thousand miles on it, I'd be inclined to think "timing chain." He says piston slap. WTF?
Advice and or input is appreciated before I find myself in a full engine teardown when all I needed was a timing chain. For what its worth, engine runs perfect, oil comes out clean and amber every 3K miles, 40-60 PSI oil pressure, runs at 200 degrees all day long. Good compression and no other engine noises. Runs PERFECT otherwise.
Thanks
4.0H.O.XJ is offline
post #2 of 5 Old 08-22-2008, 05:24 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Have you used a mechanics stethoscope on your engine yet to help isolate it? Engine noises can be tough to track down and if it is piston slap, a stethoscope should be able to isolate it to a certain cylinder.
I believe piston slap usually gets a bit better as the engine heats and metal expands. Doesn't mean that it isn't piston slap that has reached a certain wear point where it stays noisy I suppose.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #3 of 5 Old 08-22-2008, 06:03 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Check the harmonic balancer and make REAL sure it's not walking back into the timing chain cover.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #4 of 5 Old 08-22-2008, 08:48 PM
vinceleonard
1987 XJ Cherokee
my cherokee was doing the same thing and the front two rod bearings were bad. i bought a set of stock bearings and a high volume oil pump since i was loseing pressure.now it runs 30 lbs of pressure after it's hot and doesnt rattle anymore.i did this in the cherokee in a couple of hours.the bearings were like four dollors a piece for each rod and the oil pump was close to seventy.i'm hopein it will hold me until i can come up with enough money to get a rebuild.hope this is of some help.
vinceleonard is offline
post #5 of 5 Old 08-22-2008, 09:05 PM
Paul_C
Since you're familiar with the knock sound of piston slap and I would agree that doesn't sound like marbles in a can. I might suspect one of the engine accessorys like the water pump, alternator, idler pulley, ect.
Paul_C is offline
piston slap 1990JEEPXJ XJ Cherokee Technical Forum 12 06-17-2011 08:30 AM
Timing Chain Noise at Cold Start smokeman XJ Cherokee Technical Forum 16 01-24-2008 06:59 PM
Timing chain slap deadboi77 XJ Cherokee Technical Forum 2 02-21-2007 08:29 PM
2.5 I4 timing chain noise RussoGuitar XJ Cherokee Technical Forum 6 11-19-2006 06:00 PM
Piston slap? timjanssen XJ Cherokee Technical Forum 9 08-18-2006 09:21 AM
