Whats do bad rear axel bearings sound like? - Page 2 - JeepForum.com
post #16 of 21 Old 02-12-2012, 10:26 AM
AZ Jeff
2014 JK Wrangler
Did you ever resolve this issue?
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #17 of 21 Old 02-12-2012, 02:39 PM Thread Starter
RamboPants
1987 XJ Cherokee
Took it to a guy yesterday and let him listen to it and he said its nowhere near the point of tearing it down and rebuilding it. We opened it and he checked it out real good and nothing was loose or binding or anything. We did find some tiny specs of metal, it was pretty much like glitter so he sprayed it down with kerosene for about an 1 and cleaned it up real good. We refilled it
with lucas 80-90 and some lucas oil stabilizer for diffs and trans cases.
RamboPants is offline
post #18 of 21 Old 02-13-2012, 07:27 PM Thread Starter
RamboPants
1987 XJ Cherokee
Still sounds like **** though............I mostly noticed when Im coasting to a stop or when i have it jacked up both wheels off the ground in Drive, 1-2,3 not as bad in R
post #19 of 21 Old 11-20-2012, 02:52 AM
mikecote24
old thread but maybe someone will see this. I have a sound coming from the back almost like a tire rubbing but its not. Its not a clunking.it gets loud when you get to about 15mph and gets louder the faster you go. Putting it in neutral doesn't make a difference. i have no play in the tires but i havent ruled out wheel bearings. When i have it jacked up and someone puts it in drive the noise is pretty much gone. Does that mean i can rule out pinion bearings because thats been what i was thinking. Any suggestions? thanks
mikecote24 is offline
post #20 of 21 Old 11-20-2012, 07:55 AM
rjbruzan
Still differential bearings.
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #21 of 21 Old 11-22-2012, 07:41 AM
Weebur
1997 XJ Cherokee
Just some general info on bearing noise:
Pinion bearings have a high pitch noise (because the pinion gear rotates faster than the carrier). Drive the vehicle and put it under load, if the noise occurs the source is the rear pinion bearing. If the noise occurs while coasting then the front bearing is the source.
Worn carrier bearings usually produce a low pitch noise that is usually present constantly and varies only with vehicle speed.
Axle shaft bearing can produce vibration and noise that will change when the bearings are under load. To check, drive the vehicle and turn sharply to the left and right. This will load one side and unload the other. The noise on the side that is under load will increase, conversely, the unloaded side noise will decrease or go away. When the damage is slight the noise will usually not be noticeable at speeds above 30 mph.
Weebur is offline
Rumbling/grinding sound at highway speeds. Wheel bearings? ChrisTJCO XJ Cherokee Technical Forum 3 02-14-2011 05:45 PM
Rear Axel Bearings: how do u get to them? midfat XJ Cherokee Technical Forum 10 08-28-2006 02:00 PM
another funky sound question, transfer case and axel jugger XJ Cherokee Technical Forum 0 09-08-2004 11:50 PM
Bad sound. Front axel. Ball Bearings? Travler XJ Cherokee Technical Forum 5 09-26-2002 10:49 AM
whats the rubber bumper that prevents the rear axel from hitting called? woobles XJ Cherokee Technical Forum 3 07-31-2002 11:03 PM
